aburkefl
Flight distance : 78612 ft
Press and hold the shutter-button on the Pilot app. A small semi-circular gizmo will appear. Starting from the top, the options are:
Single Shot
HDR (High Dynamic Range)
Burst Mode (3, 5 or 7 shots in a row)
AEB (Auto Exposure Bracketing) choice of 3 or 5 photos
Timer - choice of 5s, 7s, 10s, 20s, or 30s
Touching the space where the shutter-button was will remove this little menu and the shutter-button will become visible again.
WARNING: Whatever mode you choose - that will remain in effect as long as the Pilot app is running, or until you re-open this little menu and execute another option. Don't ask me how I know this! LOL
Can't tell you the number of times I monkeyed with the timer while testing. Every 7 seconds the shutter would go off and I would scratch my head - "...why the devil is it taking pictures..." until it finally dawned on me that it was only doing what I told it to do!
To add insult to injury, if I remember correctly, you could actually choose the burst mode, select 5 pictures, then set 7s on the timer - and, yep, every 7 seconds you're going to get a burst mode of 5 pictures. Since your Phantom is in the air while this is going on, it's probably not what you really wanted. If you're truly doing something like a time lapse, you probably want to be hovering as quietly and carefully as possible. |
