GJ 8
Flight distance : 34360 ft
This topic was mentioned earlier under camera connection problems, but it goes further.
After updating to firmware -300 first the Inspire 2 was reacting erratic to yaw inputs, at the same time the gimbal was having a life of its own, both yaw control and gimbal seemed connected and were interfering with each other. Restarting the drone fixed that (I thought).
Now, when using dual controls, whenever I (or rather my cameraman) pan(s) the camera (MUSE 5) the gimbal will return to center position in 1 second, while the gimbal setting is in FREE mode, tilting the camera works oke, both with the camera remote and with the tunrwheel on the master controller. Also I receive warning about lens disconected while the lens is fully connected, no damage or debris. The camera has problems focussing, manual focussing (tapping the screen in DJI GO 4) is needed frequently.
Also, sometimes I receive warning about controller firmware update needed when all firmware is latest available installed.
Inspire is almost new, all firmware (drone, remote and batteries) is supdated to latest version (-300), IOS is latest version (11.2.5). Removing the app and re-installing does not work as suggested by other fora. Changing remotes from master to slave has no impact, other than when changing, the new master indicator flashes red/green in a strange frequency. Changing gimbal mode between follow and free has no impact, looks more like it is not working at all. Testing on the ground without the app makes no difference, the gimbal does not do what the controller tells it to. BIT test of the gimbal at start up works fine. |
