The theme speaks for itself. Just want to say that after purchasing the drone I have flown about 23 km and everything was fine On the penultimate day of my trip to Vietnam and Malaysia I was in the city Dalat. For the filming of this province it was chosen one of the highest points in the area Pinhatt mountain. It is just a plateau with a radius of 40 meters at an altitude of about 1650m comfortable enough for take-off platform without signal interference. Here you can find some of the most impressive places to enjoy landscapes of Dalat ( https://turavietnam.com/the-7-best-viewpoints-in-dalat/). For the completeness of the shooting I was doing a flyby of the area to the North of the home piont. 14.01.2017 at 2 pm I started the flight with full battery and pre-take-off, despite automatic setting point home, I have established the point of return home for 100m ( this is above all the trees in this area including the highest point of the takeoff). Flying somewhere 1 km I started the return with a small decline to shoot a few mountain ranges below. I did not make sharp cuts, and in General kept shooting very smoothly for cine pictures. But link was beginning to crash quite dramatically and I could not return the drone to a height to restore the connection. Need I say, that the loss of connection has happened to me often in Kuala Lumpur because of the high skyscrapers and I've always managed to return the Quad in the signal area. But in this case it hung and didn't listen to taps on the sticks of the remote control - last I saw on the screen is the trees following the course home. I tried to run in the Eastern part of the "Pinhatt" plateau in order to try to find a signal. It didn't help I tried going down to 100 meters below the plateau, which also gave no result. I decided to wait for a drone waiting to begin the automatic return to home. However, this did not happen!!! I was very frightened precarious situation, and wrote into the channel a telegram the community of fans of drones to help in further action. I was recommended to go to the last known coordinates without turning off the remote control. Taking into consideration that the area was mountainous, dominated by coniferous trees and tropical jungle in the lowlands, the way to the point took about an hour and a half. Unfortunately near the point coordinates to get the connection also failed. I was looking for the drone to full discharge control in the jungle and it took about 4 hours. More to continue the search I could not as it was getting dark. Overall this was a great risk, as it was not a single soul in this district and it was a wild forest. Despite this the next day I made a second attempt to search as half of the videos is on the SD card in the device. Here I have decided to record the route search: https://ru.wikiloc.com/wikiloc/view.do?id=22049768 . More than two-hour search gave no result. In the end, I lost two days of vacation in the jungle in search of the drone, which did not return to normal mode at the place in your home. I did everything I could in order to avoid the loss of the aircraft and never made a mistake in piloting. I am very upset by losing my drone and a very important videos (there is of course my fault to transfer it to laptop, but I didn't plan to lose the device). I believe that this is the fault of a software failure of the device. Here you can see the log of the flight and make sure there are no errors, piloting and environmental impact: http://app.airdata.com/main?share=GGPauj
I sent this email to the support. They responded quickly by asking associated questions for the registration of the support request. Then just disappeared and didn't respond for 3 days. Is this normal? How long usually need to wait response from DJI?
