jfredrickson
I was flying my Spark today and switched to a new battery that I had just purchased and charged overnight and when I turned on the Spark with the new battery, it wouldn't connect to the controller. When I open the app and click "Enter Device" it says I have to either "Activate the Aircraft", "Connect to the Aircraft's Wi-Fi" or "Enter Camera View".
When I try to "Activate the Aircraft" it won't scan the QR code because it has been worn off slightly. When I click "Can't read the QR code" it says to connect to the Aircraft's wifi to try activating that way.
So when I try to the "Connect to the Aircraft's Wi-Fi" option and select "Aircraft Combo" I get through the steps until the last step where it says to hold the power button on the Spark down for 3 seconds until I hear a beep and then click the "Link" button in the app. Unfortunately, when I hold down the power button on the Spark nothing happens. I tried holding it for 3 seconds, 6 seconds, and 9 seconds, all of which did nothing. When I click the "Link" button in the app, the controller starts beeping and the app counts down from 60 and nothing happens.
When I got home I charged up the original battery and restarted the drone and it still is unlinked even with that battery.
I then tried downloading the DJI Assistant app and connecting the Spark to my Macbook but it doesn't show up in the app. Yes, I turned on the Spark first and restarted my Mac after installing the app. No luck.
So it seems that my Spark is stuck unlinked and I can't reset it to relink it or connect to it via Wi-Fi directly from the phone or through the computer.
Is there anything else I can do to reset it and try linking it to the controller again from scratch?
