Crystal Sky with Mavic Air?
2771 12 2018-1-24
RandyHat
Will this combination work?  Will the Mavic Air controller accomodate the 5.5" version of the Crystal Sky?...or will an adaptor be required?
2018-1-24
Wachtberger
Flight distance : 261509 ft
The dimensions are identical (including Spark). Thus if it has fitted for Spark and Mavic it will also fit with Mavic Air. What I am not sure about is whether the Mavic Mount will still work (I use a different mount anyway) and which GO4 version we shall need on CrystalSky in order to get all Air functions. Apart of these details I don't see any other why CS should not work with Air.
Mavic Air:
Supported Thickness: 6.5-8.5 mm
Max length: 160 mm
Mavic Pro:
Thickness Supported:6.5-8.5mm
Max length: 160mm
2018-1-24
Buzzyone
Flight distance : 4647913 ft
Wachtberger Posted at 2018-1-24 08:22
Mavic Air:
The Go 4  app has been updated for the Air, so unless the CS gets an update it won’t support all the functions of the Air.
2018-1-24
Wachtberger
Buzzyone Posted at 2018-1-24 15:05
This is quite much what I have expressed in my post ;-), but thank you for underlining it. But my assumption is that the GO 4 version 4.2.4 released the same day as Spark is for iOS and that the Android version is still to come for both normal Android devices and seperately for CS. So let's cross fingers that  we shall get it by the time we shall hold the Air in our hands.
2018-1-24
DJI Elektra
Randy, they are compatible with each other. Thanks for your attention.
2018-1-25
eColumbia01
Expanding on this question a bit - it looks like there is a method to connect the larger 7.85" Crystal Sky to the mavic controllers without fitting into the controller arms itself. Is there a method to connect the larger crystal sky devices to all the mavics including the mavic air?
2018-1-25
Wachtberger
eColumbia01 Posted at 2018-1-25 10:54
I do it this way:
2018-1-25
lannes
Flight distance : 4465 ft
https://forum.dji.com/forum.php?mod=viewthread&tid=130922
2018-1-25
eColumbia01
Thanks for the pics showing the mavic and the crystal sky mount.
2018-1-25
MauiMaps
DJI Elektra Posted at 2018-1-25 01:40
LINK  --  Mavic Air and CrystalSKY mount adapter?
@7:45 CrystalSky mount does not properly fit Mavic Air RC
2018-1-25
fansa1395e05
Flight distance : 967316 ft
I just got my Mavic Air and I tried to connect to my CS 5.5" monitor and it DID NOT work with my Mavic Air.  My CS version is the latest V02.04.06.00.  I checked to see to if there is a newer version that I can install on my CS and as of Feb 7th, 2018 there is no newer firmware for CS.  If someone knows where the new firmware for CS please let us know.
2018-2-7
Wachtberger
fansa1395e05 Posted at 2018-2-7 05:15
It has not been released yet. Until we get GO4 version 4.2.4 for the CS we will not be able to use it with the MA. I really hope the update will come soon.
2018-2-7
hallmark007
Flight distance : 9827923 ft
Mavic Air:
I can confirm dji fitting for Crystalsky which fits both spark and Mavic controller, DOES NOT FIT MAVAIR RC. pity because it’s pretty expensive.
2018-2-7
