Notice on compatibility issues between iOS 11.2.5 and DJI GO or D...
45046 192 2018-1-24
SeaComms
Flight distance : 568222 ft
So despite this thread being in the Mavic forum, it would seem for the first post that the Mavic is not affected? My iPad had already updated to 11.2.5 but I was on the previous GO4 version until this morning when it auto updated....  if this is a problem why have the auto update to the latest version?
2018-1-29
JensIR
Flight distance : 207631 ft
SeaComms Posted at 2018-1-29 23:05
SeaComms, it seems that all threads that are put as "sticky" at the top of the thread list by the admins will appear in all forums across. Seems to be limited functionality in the forum software.
I got a new iOS device and updated to 11.2.5 without being aware of this potential problem. So far it does appear that it does not affect my Mavic Platinumn at least, just like the information indicate. I have since upgrading flown 5 or 6 batteries with no issues.
2018-1-29
noflyzone69
Flight distance : 240361 ft
HURRY UP DJI FIX THIS !!!!!
2018-1-30
Lucas775
Flight distance : 50642090 ft
Got a new FW update and I’m at work
2018-1-30
Lucas775
Lucas775 Posted at 2018-1-30 04:17
Is this the fix???
2018-1-30
CanonMax
Flight distance : 8953215 ft
As it states in the description... I am going to connect my Phantom 4 Pro (NO HDMI) moduile right now...
2018-1-30
CanonMax
2018-1-30
CanonMax
Captain... it says nothing about a Firmware Update on my screen... I'll double check it for you (I am running Phantom 4 Pro FW V 01.05.0300 (December 25th 2017)...
2018-1-30
Lucas775
CanonMax Posted at 2018-1-30 05:00
The FW update came up was for the DJI go not for DJI go 4, I was hoping this would fix the problems for the Inspire 1.
2018-1-30
CanonMax
Only the DJI GO 4 app has been changed (The DJI GO app was also updated earlier today to V 3.1.27... all other databases are OK here and do not need to be updated... FW of the remote controller did not change either (V 01.04.01.00) and it also seems the batteries are OK and do not need an update...
Test flight... I cannot do that right now because of the weather... grrrrrr
regards,
Mac
2018-1-30
CanonMax
regards,
Mac
2018-1-30
Sebi
Flight distance : 5089226 ft
Poland
NEW DJI GO 4.2.5 AVAILABLE
- Fixed bugs causing app crashes when using a Phantom 4 with an HDMI Output Module.
2018-1-30
Kansas Boy
Flight distance : 26145 ft
The latest DJI Go 4 version that was posted last night (4.2.1) fixed my issues with the my Phantom 4 Pro.  Thanks DJI.
2018-1-30
Sparky_17
Flight distance : 62349 ft
I'm assuming this doesn't impact the Spark
2018-1-30
CanonMax
Sebi Posted at 2018-1-30 05:30
yup... all seems ok.... but I do not own a Phantom Pro 4 with HDMI-module
2018-1-30
userd6c136983c
Flight distance : 105715 ft
Peterx Posted at 2018-1-29 11:24
The Go app version 3 was updated in the same day as the iOS. Now i have iOS 11.2.5 and the go app version 3.1.26 and with my P3S i got all data and a life picture on the ground. If the weather allows it then i make a test in the air. I think these issues are present on all light bridge AC´s as P3A/P all P4´s and Mavics as well.
Very confusing, I am also running all the latest updates and my P3S and P3A seem to be functioning normally on the ground at least.. I haven’t worked up the nerve to put either in the air yet. I’ll wait and see if some kind of a patch is issued.
2018-1-30
Lucas775
Does anyone know if it fix the visual with the Inspire 1 using iOS?
2018-1-30
mixchief
Flight distance : 182057 ft
Auto update is under your control
2018-1-30
mixchief
Anyone download iOS build 27 yet? I can't hasn't been made available to me yet
2018-1-30
Peterx
Flight distance : 1499708 ft
Keule Posted at 2018-1-29 20:33
DJI is working on the problem and released a new GO version 3.1.27
Danke für die Info (thanks for the info)
2018-1-30
fans558cdb54
I'm on apple's iOS 11.3 and the issue has been fixed.
2018-1-30
Lucas775
fans558cdb54 Posted at 2018-1-30 11:13
Good to hear.
Thanks,
2018-1-30
PilotC
Flight distance : 1321214 ft
if you roll back wounldn't apps that have updated and expect ios 11.2.5 may stop working?
2018-1-30
ASTURDRON
Flight distance : 213471 ft
The last update of the app dji go 3.1.27 still does not work with matrice 600 pro+zenmuse Z30 with ipad air 2 (ios 11.2.5).
when you get the application, osmo mobile update comes out.
2018-1-30
PhotoSkyView
Flight distance : 1898005 ft
Puerto Rico
jangermann Posted at 2018-1-24 08:48
Too late. How do I roll back?
http://www.iphonehacks.com/2018/ ... 2-5-ios-11-2-2.html
2018-1-30
HDPS
Flight distance : 44957 ft
My still version 4.2.4  (non operating with iPad4 Mini), I turned on everything and was not prompted to upgrade to Version 4.2.5
How have you got the 4.2.5 ?    I don't want lose my data by deleting the 4.2.4 and install DJI GO again from scratch......even if there is a way to save it, have no time to fuss around.
2018-1-30
N8JYF
Flight distance : 2122077 ft
Phantom 4 Pro with HDMI module, iPad 4 Mini 4 with Verizon LTE
After today's update to DJI GO4 4.2.5 (iOS 11.2.5) I am flying again.
I put four full batteries through it on a cold day and it was responsive,
never lost video signal, had good range and all camera functions work.
I am happy again.    Honestly if I didn't know better, I'd say it has never flown better.
I really tested the range and speed to.  All as expected.
Thank You DJI, I forgive you - but will never ever ever update again without waiting a week.
Scott
2018-1-30
HDPS
N8JYF Posted at 2018-1-30 17:35
And how to install? I turned all on and was not prompted for update, went to apple store, saw the 4.2.5, click open and bring me to the GO4 4.2.4  and no upgrade.
Will need un-install the 4.2.4 and install the 4.2.5 ? how about the data?
Anyone? DJI Support?
2018-1-30
Lucas775
Fixed! thanks DJI.
2018-1-30
Grumpybeard
Flight distance : 593356 ft
Switzerland
Has this issue with ios 11.2.5 and DI Go 4 been confirmed as resolved by DJI themselves?  Has the warning prompt been removed when launching the app (where you confirm with "I know")? Thanks
2018-1-31
Locoman
Flight distance : 748675 ft
HDPS Posted at 2018-1-30 18:17
if you sync all your data before you delete GO4 app, and sync all data after installing new app, all your data should be there
2018-1-31
Aardvark
Flight distance : 384432 ft
When you go to Apple store you will see some icons at bottom of screen, if you tap on the 'updates' one (4th icon from left) then that should display any updates available for App's on your device. You can then chose which to update, or update all.
2018-1-31
fans9d9d29d3
Philippines
For IOS 11, go to Settings, General, iphone storage (wait fior it to load and scroll to the bottom until you see DJI Go 4 app, click the arrow, click Offload App.
Only the DJI GO 4 app will be uninstalled. All data will be saved.
Reinstall DJI GO 4 app. The latest version will be installed,
2018-1-31
fans9d9d29d3
Philippines
The above instruction is to update DJI Go 4 version 4.2.4 to 4.2.5 when the App Store does allow you to do it. This will uninstall version 4.2.4 without deleting your data. Then you can install latest version and find all your data intact. Happy flying!
2018-1-31
SOUNDWAVE439
Flight distance : 115597 ft
Wow this REALLY helps doesn’t it
2018-1-31
deadpixels
Flight distance : 1258064 ft
Close but not all there. I was able to connect to phantom  4 standard with HDMI module while running go4 on IOS 11.2.5. The problem is if the screen is turn off  or app put into background. connection is lost.  Almost every time I deliberately did this I was able to reconnect  by closing app, unplugging USB reconnecting USB and restarting app. Only once did I have to restart the RC to get connection again. Not a big confidence booster.  Be very cautions till this is completely fixed.
2018-1-31
RangerOne
Flight distance : 2331132 ft
Wirezfree Posted at 2018-1-27 16:48
I really struggle with this...
Why would DJI pay DJI software developers to constantly keep changing/updating code whilst Apple keep updating(beta) there software.?
That really doesn't make sense.  If you're a software developer, you need to test your software on the operating system it runs on.  Operating systems change all the time, so you need to make sure your software is compatible.  Sure, along the process you also help test Apple's software and you can report bugs if they impact you, but that's how you BOTH ensure a quality product.
It's not like Apple doesn't test their software.  They EXTENSIVELY test it, but with any complex codebase there are issues that can escape QA just like there are issues that escape even extended beta periods.  The same is true of DJI -- we can't expect them to be perfect, but to have an app that won't even connect to your remote controller should never escape QA.
Also, as an iOS developer, I appreciate the beta period.  It would be CATASTROPHIC if Apple released a new OS and suddenly my apps crashed on startup or were otherwise significantly broken.  Multiply that times a few million app developers, and Apple's app review process would be completely overburdened with bug build requests and it might take  several weeks to get a fix out to your users.  That's a recipe for pure Hell right there.
2018-1-31
Wirezfree
Flight distance : 17999 ft
RangerOne Posted at 2018-1-31 11:14
Thanks...
You have highlighted the issue..
You are a developer, you need the BETA to prepare for the next official release.
Giving that BETA to users also is the issue, they have got it before you are ready.
2018-1-31
TurboTom
Flight distance : 103333 ft
Hi DJI, letting you know this update is better, but is still buggy for me. I've only done a desktop test so far, but what happens is it connects when turning on the drone (Inspire 1), RC and iPad, however, if i minimise the app or access any other app, it disconnects from the drone. It does reconnect when I close and reopen the app, unlike before when I had to restart all 3 devices! I have a similar issue with GS Pro, except that requires an app and RC restart before it will reconnect! Looking forward to updates to both apps ASAP please as I’m not confident that something won’t go wrong mid-flight!
2018-1-31
fansec041900
Trinidad and Tobago
Application still buggy or Spark needs a new firmware to work with it.  Update to newest GO app and began receiving calibration issues.  More than 10 successful calibration before my Spark was able to fly and this never happened before 11.2.5 and I also received a Gimbal issue where it just began moving erratically.
I know OTG is not supported but I also tried it and got the range without interference but I was also unable to switch to photos, software was locked in video mode.
New patch still a bit buggy with the Spark
2018-1-31
