MarWu
Flight distance : 11555 ft
Assuming that the FCC range for FCC with 631 mW (2,4 GHz) and 1259 mW (5,8 GHz) is reached and assuming that the received power decreases with ^2 of the distance, you could calculate the range for the CE standard by:
range_CE = range_FCC * sqrt(power_CE / power_FCC)
Whith these assumptions you get 1,4 km (2,4 GHz) and 563 m (5,8 GHz). Just to be clear...these are basic calculations, which only take the emitted power into account and none of the other mentioned factors of influence. |
