OTG Support on Android
12Next >
7896 44 2018-1-24
Spark User 06
Hi there,
I know that the  subject has already been raised several times but I understood that the  problem of OTG support has been set to IOS with the latest version of  DJI GO and I also noticed that the Mavic Air supports OTG connection and that it has the same type of WIFI connection as the Spark.
So the question is for DJI, when do you think you can restore the OTG function on the Spark for Android ? Because it seems that you can resolve it easily...
2018-1-24
S.J
Flight distance : 322454 ft
India
you got to use Mavic Air if you require OTG support
2018-1-24
eYeSkYeYe
Croatia
We still don't know if OTG works with Mavic Air and current DJI GO or updated fixed app is needed.
2018-1-24
idbl_fanatic
Flight distance : 509741 ft
eYeSkYeYe Posted at 2018-1-24 12:13
I could have sworn that the release notes for the new version said OTG support for the Mavic Air
2018-1-24
eYeSkYeYe
Croatia
idbl_fanatic Posted at 2018-1-24 12:25
I watched a couple of review videos. None of them shown working OTG connection.
2018-1-24
dj_dread
Flight distance : 648399 ft
Romania
check the "fly more" in the DJI Store. the combo includes OTG cable(s). Yes, it has OTG support for Mavic Air
2018-1-24
eYeSkYeYe
Croatia
So you guys stating OTG works for Dji Go 4.1.22 for Android and Mavic Air RC? My understanding was we have to wait for the new version of app where it eventually will get fixed.
2018-1-24
dj_dread
Romania
it seems Mavic Air is different than Spark. so OTG works for Mavic Air. that is my understanding
2018-1-24
eYeSkYeYe
Croatia
Still weird that 0 out of 10 reviews did not show working OTG as pretty important thing with wifi link.
2018-1-24
Nidge
Taken from the Mavic Air FAQ
1.Can I connect my smartphone to the remote controller using an ordinary USB cable?
Yes. You can use an ordinary USB cable to connect your smartphone to the remote controller via the USB port at the bottom of the controller, but this may result in more discomfort when handling. Different cables come with the aircraft to meet your needs.
2018-1-24
eYeSkYeYe
Croatia
Now this is weird. OTG cable is definitely not ordinary USB cable but special one with pins 4 an 5 shorted on one end. More and more puzzling...
2018-1-24
kovat53
Flight distance : 324521 ft
Hungary
S.J Posted at 2018-1-24 12:09
Would you please explain, how is it posiible to use OTG for Mavic Air, but is not possible to aplly for -spark. It seems formerly SPark used it as well. What is behind the story? Why did Dji annul OTG?
I do understand, new stuffs bring more, but Spark itself  is not so old product, and it is unusual to cancel a very important - mainly for the flight safety -skill. I would highly appreciate a clear answer. Thank You
2018-1-27
kovat53
Hungary
Don't you think it is a very  cynic answer. So anyone, who payed enough bucks for the Spark, that time with OTG enabled., and now anyone, who wants OTG,, should by another drone for more bucks. Do you call it a correct solution
2018-1-27
Wachtberger
Flight distance : 261509 ft
kovat53 Posted at 2018-1-27 03:40
As a matter of fact OTG was not a promised feature (and clearly not an intended one) when you have bought your Spark. Just use GO 4 version 4.1.15 and you have your OTG (as I do myself). You won't miss any features doing so until the official OTG support will come as promised by DJI for the future.
2018-1-27
hallmark007
Flight distance : 9827923 ft
eYeSkYeYe Posted at 2018-1-24 13:24
All of the videos on you tube show otg working on MavAir, it doesn’t use usb in the centre underside of the RC, it uses connection from left hand side just the same as Mavic RC.
2018-1-27
johnnybflyguy
Flight distance : 533681 ft
eYeSkYeYe Posted at 2018-1-24 12:48
The latest Go 4 App is  4.2.4 both for iOS and android.
2018-1-27
kovat53
Hungary
Wachtberger Posted at 2018-1-27 03:46
Thank You, very much!
2018-1-27
S.J
India
kovat53 Posted at 2018-1-27 03:34
The question about OTG compatibility has been raised several times to DJI through the forum. There is no positive action  from DJI even though it "seems"  to work for earlier versions of the DJI GO4 apps.
But in my understanding they are doing all they can to " stop" providing OTG support even for the earlier versions as until this moment they are unable to provide any further information on the subject.
i use an android mobile.
2018-1-28
Far_North
Flight distance : 278379 ft
I see no reason to believe that Spark OTG support for android devices will ever be supported by DJI.  I'm sure DJI have their reasons but I just wish they would come out and say unequivocally one way or another if Spark Android OTG support will ever happen.  This way we can forget about it and move on.
2018-1-28
hallmark007
Far_North Posted at 2018-1-28 06:36
They have continually said here on this forum that engineers are working on this, we se from this week improvements in iOS support for otg , so maybe they are working to try to gain support for Android.
They are continually repeating that at the moment it hasn’t been fully tested, if you don’t need or want it then don’t worry about it, if you feel you need it, then dji coming out saying it will never be supported is going to be a major problem for you, so I’m sure this group of people will not welcome dji making this statement.
2018-1-28
kRx md
Flight distance : 158914 ft
Philippines
@Far_North
Agree. so we can #forget & #moveon.
2018-1-28
djiuser_vNUSVs1
I have updated the DJI Go 4 app to 4.2.4. and am using Huawei P9 Plus running Android 7.0. I use OTG to connect to the RC and find out that there are no Distance, Height, wifi Channel used and GPS satellites readings.The Spark flies as normal with stable video transmission. Is it normal for Android users?
2018-1-28
Dondon04
Flight distance : 19931 ft
Philippines
Same here, I've updated to DJI Go app to 4.2.4, I'm using Samsung Edge 7 on Android 7.0. When I use OTG, there's no telemetry data, only video feed. I also tried connecting my old Nexus 7 (2013) using OTG with the same results.
Any of you guys who were able to see full telemetry data using Android on the new DJI Go 4.2.4 app? If so, what Phone/Tablet were you using?
2018-1-29
chareon
Flight distance : 11850 ft
Philippines
tested on the latest android app 4.2.4 (huawei mate10 lite) same issue no data on battery and others. reverted my app to 4.1.15
2018-1-29
Jos A
Flight distance : 73209 ft
No OTG for 4.2.4 android,  known issues are not fixed, only an addon for the Mavic Air
2018-1-29
kovat53
Hungary
.....  until the official OTG support will come as promised by DJI for the future.....
Was it promised?
2018-1-30
Wachtberger
kovat53 Posted at 2018-1-30 05:27
Was it promised?
Yes there have been a number of clear statements that they are working on it and that it will come.
2018-1-30
djiuser_Kf4iPA3DtL3S
Flight distance : 510968 ft
Israel
If they re-enabled it for iOS, then obviously they don't intend to abolish it. I don't know why it's been held back in Android, but in light of the iOS development I haven't given up hope... until then, 4.1.15 stays.
2018-1-30
kovat53
Hungary
djiuser_Kf4iPA3DtL3S Posted at 2018-1-30 06:33
I know it's heavier to develop an application for Android because of the variety of  the phones and different variants of Android itself.  It is  obvious  to develop for IOS much more easier. Anyway they are (must be) aware of this fact at DJI  and they put theirs app to GooglePlay, . In Europe, where I live, the 5.8 GHz only communication makes our droning life difficult sometimes even unpalatable, that's why we are praying for the OTG.  OK, I  downgraded to 4.1.15, but  - in my opinion - it is not a real solution. I should stay forever at a never developed  technology, but what yield came then. SoI 'm just hoping OTG will be back soon.
2018-2-1
lumidair
Slovakia
kovat53 Posted at 2018-2-1 00:17
@DJI please help us...
2018-2-1
Rodador
Flight distance : 427520 ft
Wachtberger, may I ask what version of Spark and battery firmware are you using?
Reason I ask is I am also using Android app Go 4  version 4.1.15 and I am using Spark firmware .701 because everything I have read so far says this is the most stable combination but I have been wondering if by chance the old app is compatible with the new firmware.
Thanks in advance!
2018-2-1
ArnoSpark
Kenya
Rodador Posted at 2018-2-1 00:52
Mine using the 4.1.1.5 and latest firmware OTG working very well no issues
2018-2-1
Wachtberger
Yes I can confirm that .15 works well with the latest firmware and I would also recommend to update to it.
2018-2-1
kovat53
Hungary
lumidair Posted at 2018-2-1 00:28
I use 009 fW on AC and 4.1.15 on Go 4. It works.
2018-2-1
LeChuck71
Flight distance : 68786 ft
Latest FW and 4.1.15 (Android) -  OTG works perfectly
2018-2-1
Edd_88
Confirm. 4.1.15 work perfectly with the latest firmware (009 as of today) so far.
2018-2-1
BeastMaster_101
Flight distance : 1082992 ft
OTG support for my LG G5 is negetive with latest update
2018-2-1
eYeSkYeYe
Was it promised?
Yes, it was. Catch is that timeframe in which it will work again is not mentioned anywhere. And if support comes up in like 2 years, it will be pretty irrelevant.
2018-2-1
Rodador
Wachtberger Posted at 2018-2-1 01:53
Thank you everyone for the responses. I love the forum because of the friendly people willing to help a new pilot.
2018-2-1
kovat53
Hungary
eYeSkYeYe Posted at 2018-2-1 06:39
I wrote directly to DJI Support. Let me cite from the answer:
......  let me inform you that Spark is designed to be a ready-to-go WiFi drone and we do not advise the use of OTG connection. Using the OTG connection has not been tested by our field application experts and is a function that we do not recommend. Although, WiFi maybe interfered than an OTG connection, still, Spark is designed that way which is why you really need to fly in an open area away from interference. Try using your Spark under normal use and it will be safer as telemetries on the app will show app more accurately......
I think it is clear for everyone, who uses Android device. For me it means: there is no plan for getting back OTG  for Spark. Perhaps i am wrong.
2018-2-5
12Next >
