Mavic Air battery charging question
6031 13 2018-1-24
CynicalZombie
Flight distance : 179813 ft
I own the Mavic Pro... with the Mavic Pro batteries you can't charge them in the field with a normal USB power bank (the portable kind I can charge my iPhone, iPad, UE Megaboom etc.).  If I recall, it was it's because the voltage necessary for the battery was to high for a USB power bank.  Is that the same for the Mavic Air?
2018-1-24
AG0N-Gary
Flight distance : 700846 ft
I would say yes.  Look at the number of MAH that needs to be supplied to charge the battery.
2018-1-24
DJI Thor
Flight distance : 13602 ft
Hi, the answer is negative. The battery can not be charged by the power bank.
2018-1-26
Ozziebattler
Flight distance : 5341982 ft
Hi, I also found out tonight that you can top the Mavic Air battery off same as the  P3 and Inspire 1 batteries
2018-1-31
Tadango
Flight distance : 232359 ft
Get a AC powerbank and you can charge everything I bit heavy though.....
2018-1-31
rantanlan
Flight distance : 69698 ft
There where several reviews which state not.
2018-1-31
vootshi
Hi guys! Do you think this combo will work?
2018-2-14
Wyke
Flight distance : 33166 ft
vootshi Posted at 2018-2-14 05:14
[view_image]
My guess is no, as I doubt the voltage and current output of the adaptor, with a 5v input, would be high enough
2018-2-14
Buzzyone
Flight distance : 4698707 ft
[view_image]
I doubt it, the DJI car charger needs a healthy ‘12V+’ supply, typically your car supplies 13.8 to 14.4v when running, there have been numerous threads about the Mavic Pro car charger not charging, essentially down to the supplied voltage not being adaquate to ‘get it going’..
2018-2-14
djiuser_OTA2mNM5C9Ih
Flight distance : 122900 ft
Anyone bought Mavic air car charger? How was the charging speed compare with using direct DC charge?
https://store.dji.com/product/mavic-air-car-charger
2018-4-14
Even can see 3 in 1 Car Battery Charger Accessories for the DJI Mavic Air Drone. Is this compatible ?
https://www.amazon.com/DJI-Mavic-Air-Car-Charger/dp/B07B78K9R7
2018-4-14
Pre2k
djiuser_OTA2mNM5C9Ih Posted at 2018-4-14 21:11
I try this when dji was out of the car charger and had to return it don't know if it was the one I got but charge time for 2 battery was 90min got you 67%-76%
2018-4-15
Pre2k
if anyone want to try there's this one to but I think it's BS @ 25000mAh it say it will do 4 full charge
https://www.amazon.ca/gp/product ... smid=A1BPPQ9788JIQY
2018-4-15
Malaysia
Pre2k Posted at 2018-4-15 06:25
https://www.amazon.ca/gp/product/B07C4XCGBY/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A1BPPQ9788JIQY
This will be  burden to carry during travel.
2018-4-17
