Firmware v1.11.30 (why is this not an official release)
123Next >
14101 96 2018-1-25
KenDuke
Flight distance : 50837 ft
DJI Susan Posted at 2018-10-27 00:39
Hi KenDuke, may I have more details about the loose gimbal control from the remote? Does the aircraft and RC link well? What's the current firmware version of the aircraft and RC?
  Image of firmware for AC, RC, and App
Says all is up to date on the app.
Using the blue dot on the screen to move the gimbal does this.  It shows the slider bar on the screen, but, still does not move.
Once the blue dot goes off the screen, the slider bar sort of fades away.
2018-10-27
DJI Susan
KenDuke Posted at 2018-10-27 16:26
[view_image]  Image of firmware for AC, RC, and App
Thanks for getting back to us. Just to verify, do you refer to the dot that I marked? Sorry, I'm a little confused.
2018-10-29
KenDuke
@DJI Susan  Here is the video of the issue, and of the blue dot I was talking about.
This should clear up the confusion.
I've tried the C1 and C2 button press and hold, along with the shutter button, with no change.
2018-11-1
fans930e82dc
Flight distance : 25364 ft
Argentina
DJI Susan Posted at 2018-1-26 00:04
Anderson, I've received and replied your message in PM, please check and try later.
Hello Susan, can you please give me the link for the version 1.11.30? Thank you
2019-1-14
djiuser_sDmY4X48LtFh
Hi can I please get the new firmware sent to me to overcome the esc error I am experiencing on my phantom 3 advanced since upgrading to the latest firmware on the website. Cheers
2019-1-16
DJI Susan
fans930e82dc Posted at 1-14 14:26
Sorry for the late response. I've sent you a message in PM, please kindly check whether it is the correct one, thank you!
2019-1-16
DJI Susan
djiuser_sDmY4X48LtFh Posted at 1-16 00:34
Hi there, please kindly check the link I sent in PM and see whether it helps.
2019-1-16
DJI Susan
KenDuke Posted at 2018-11-1 07:25
Sorry for the late response as I just read your comment. Yes, hold the screen for a certain time, a blue ring will appear, you can drag it up and down to control the gimbal's direction. The little dot on the right just to show the scale of gimbal's direction.
For the gimbal dial, you may try to reset the gimbal settings to check.BTW, please click the reply button under my message so that I can get the reminder and handle it timely, thanks!
2019-1-16
gnaw
Could you please send me the Update v1.11.30, I also got a ESC status Error after updating on v1.11.20. Thank you
2019-2-7
Kobrovnik
Czechia
Hi, I need Firmware v1.11.30. I have error ESC ...Thanks for speedy... :-/
2019-3-9
DJI Susan
Kobrovnik Posted at 3-9 02:50
Sorry for the late response. May I know which drone do you refer to? I've responded to you in PM, please kindly check later, thank you!
2019-3-10
DJI Susan
gnaw Posted at 2-7 04:37
I've received your message in PM and responded as well, please kindly check later.
2019-3-10
Kobrovnik
Czechia
DJI Susan Posted at 3-10 02:30
Hi i have phantom 3 advanced thanks - fw for eror esc
2019-3-12
DJI Susan
Kobrovnik Posted at 3-12 07:42
Received with thanks! I've sent the link in PM again, please kindly check later, thank you!
2019-3-12
AntiDJI
Thailand
DJI Susan Posted at 2018-2-1 01:34
Marben, I feel the pain, sorry about this. Please check the message in PM and see whether it works.
why is this not an official release after 2 years? as a network security engineer and ex dev, i can only say that i'm appalled at how buggy the DJI software is. i DESPERATELY need the P3A 1.11.30 - i've spent five hours fixing numerous glitches, from the incorrect aircraft being identified, to not being able to update my batteries because i can't get my hands on the latest firmware. no wonder boeing has had so much trouble with the 737 MCAS, US policy appears to be to beta software in the marketplace...this is totally unacceptable. words cannot describe my frustration with this second rate company...
2019-3-27
DJI Susan
AntiDJI Posted at 3-27 05:10
Hi there, I understand your point and very sorry for the inconvenience. There might be no official release as the issue only appears certain models of P3 series after multiple testings. It is only applicable for the ESC error after updating to the latest firmware V1.11.20 successfully. If you encounter other troubles, please kindly provide us with more details. we'll try our best to help.
2019-3-28
djiuser_rkrEoLHSxqQi
Denmark
Hello Dji Susan,can i get this fix after unsuccesfull update P3 Advanced, and now experiencing the ESC error??Thanks in advance and Bless You all involved in this FIX!!
Cheers and respect
2019-4-1
Dompierre
Flight distance : 3573 ft
Hi Suzan,
Can you send me also the update 1.13  On My unit, I loose the video link as well no mater where the drone is. close or far.
Thanks.
My drone is a P3Pro.
2019-4-1
Jaybea
Flight distance : 229970 ft
Hi Susan,
I too have a ESC Status Error on my Phantom 3 Advanced running V.1.11.20 firmware.  Could you please PM a copy of the V.1.11.30 firmware.
Many thanks in advance.
Regards,
John
2019-4-3
nizamf21
Flight distance : 34442 ft
Indonesia
DJI Susan Posted at 3-12 22:43
hello dji susan I have the same problem in the case of ESC error phantom 3 pro sy, in some forums using fw v1.11.30 p3 pro this problem can be solved ... how can I get the link fw, thanks dji susan
2019-4-9
DJI Susan
nizamf21 Posted at 4-9 03:32
Sorry for the inconvenience caused. I've sent you a message in PM, please kindly check later, thank you!
2019-4-10
DJI Susan
djiuser_rkrEoLHSxqQi Posted at 4-1 09:58
Cheers and respect
Sorry for the late response as I just read your message. I've sent you the link in PM, please kindly check whether it is the correct one, thank you!
BTW, if you need one's attention, please click the reply button under one's message so that he/she can get the reminder and handle it timely.
2019-4-10
DJI Susan
Dompierre Posted at 4-1 19:39
Hi Suzan,
Hi Dompierre, just to verify, could the drone been controlled by the remote controller? For the image transmission issue, you may re-plug the cable or change to another recommended mobile device to verify.
2019-4-10
DJI Susan
Jaybea Posted at 4-3 14:51
Hi Susan,
Hey John, I‘m so sorry for the late response. The link has been sent to you in PM, please kindly check later, thank you!
2019-4-10
D3ATHCHIMP
Flight distance : 24124 ft
New Zealand
DJI Susan Posted at 2018-2-1 01:33
Sorry for the late response. I've PMed you the download link, please check later.
Hi DJI Susan my phantom 3 has just started with the esc problems. Has had crashes or hard landings.
2019-5-27
DJI Susan
D3ATHCHIMP Posted at 5-27 16:49
If the unit has been involved with crash or hard landing before, I sincerely suggest you start a case and send it in for diagnosis: https://www.dji.com/support thanks!
2019-5-29
D3ATHCHIMP
New Zealand
DJI Susan Posted at 5-29 00:44
sorry has not been involved in any crashes or hard landings, just really need to get up and running for weekend
2019-5-29
DJI Susan
D3ATHCHIMP Posted at 5-29 00:53
I've received your message in PM and responded as well, please kindly check later, thanks!
2019-5-29
Paxan
Flight distance : 181581 ft
Finland
Hi
I am having the ESC Error issue after upgrading my P3A to v1.11.20.  Please send me the link to the firmware fix for this. Thank you.
2019-7-3
fans626ac2c8
Suzan please, to fix  ESC  error,  i received from Dji Paolo a firmware «  try to restart the aircraft and if the issue still remains, kindly update the firmware of the aircraft, here is the link to download the firmware: https....If you have other concerns, please feel free to email us. »
1.11.30 .bin
The folder (unziped version) Did not update my P3 advanced atomaticaly, (as the 1.11.20 do) have you got another version?
Maxime.
2019-7-14
boots gaskin
DJI Susan Posted at 2018-1-26 00:00
Hey Chris, this V1.11.30 only fix the ESC error after upgrading the firmware which may affect a certain of drones. No need to get this if your drone works well. Also, this will not affect the warranty, no worries.
Can you please send me the v1.11.30 firmware I have a phantom 3 pro and have a esc error that is not from any crashes or hard landings or the long screws into the motors from prop guards. My drone worked fine one day and had the esc error a few days later. Thankyou
2019-8-17
boots gaskin
Can I please get this v1.11.30 firmware I’m also having the same esc error just like everyone else with my phantom 3 pro
2019-8-17
DJI Susan
boots gaskin Posted at 8-17 02:00
Hi there, please kindly check the message in PM and let us know whether it works, thanks!
2019-8-21
boots gaskin
DJI Susan Posted at 8-21 18:41
I have not received anything yet could you please resend
2019-8-29
boots gaskin
2019-8-29
DJI Susan
boots gaskin Posted at 8-29 14:02
Just resend the link in PM, please kindly check later.
2019-8-29
Takka
Flight distance : 1688448 ft
Hi Susan.I have video link and ESC issue after updating P3Pro to v1.11.20.
Could you please send me latest FW v1.11.30.
Thank you.
2019-9-2
mpas
hello I have esc error in my two drones phantom 3 pro prodria to fast me I have both versions
2019-9-4
alekseyv78
Russia
Hi Susan.
2020-3-17
djiuser_N5Q78ranXzxL
Puerto Rico
I also got the ESC Status Error Message after upgrading to firmware 1.11.20
Does the firmware 1.11.30 fixes this problem?
Thank in advance.
2020-4-11
123Next >
