Spacer2711
Flight distance : 821821 ft
No, after you have told your configuration that you are in FCC-area, it switches to this setting. Then you use DJI Go 3.1.8 (just the legal version) and this determines that you are at your current location.
But DJI Go 3.1.8 does not have the possibility to put you back in CE mode. So, you will fly in CE-area with the 'power' of the FCC-mode. What you are going to miss are the updates between 3.1.8 and 3.1.26 (for what they are worth). |
