solentlife
Flight distance : 1087530 ft
Latvia
Take the gear and find a nice CLEAR OPEN area away from roads, buildings, metal work ... a nice farm field is good.
Gardens, driveways, roads, parking lots, marina pontoons, jetty's etc. are all bad places as you have metal work / pipes / cables etc.
Once you have a good calibration - leave well alone. You should not need to do it again unless you have travelled a long way from original point - ie hundreds of miles ... or you have had major repairs / setups made.
If you arrive a site to fly and it says Interference ... or Calibrate Compass ... switch off ... move a few metres and try again ... often a piece of metal or something is there and can cause errort. Move a bit and no problem. Its best to switch off and power up again after moving - this means that warning is cleared and gear will assess new position fully.
Nigel |
