mavics gimbal get struck at an angle on start everyime
655 16 2018-1-25
djiuser_60SseuO
India
every time i start my mavic pro ,the gimbal gets struck at an angle and then the motor gets overloaded, i had to manually slightly move the gimbal everytime ( rotate the camera clock wise ) and then its back to normal for that flight alone!
and as soon as i restart the mavic it gets calibrated for once and again the camera is struck at an angle!
2018-1-25
Bekaru Tree
Flight distance : 15513100 ft
South Africa
take a photo of the gimbal and camera and post it here - otherwise check you tube for gimbal motor overload videos -
2018-1-25
djiuser_60SseuO
India
2018-1-25
djiuser_60SseuO
India
i have to manually rotate it clock wise every time at start so that it works normally!!
if i leave the drone like that the gimbal motor gets heated and shows gimbal overloaded on the phone!
2018-1-25
damoUK
Flight distance : 693038 ft
djiuser_60SseuO Posted at 2018-1-25 12:57
I think you need to send it in to DJI for repair, not sure there’s a user fix for this - or just keep fixing it yourself on every flight, as you have been, but I don’t know what the long term implications would be.
2018-1-25
djiuser_60SseuO
India
damoUK Posted at 2018-1-25 13:10
thanks for the reply mate!!
my friend got the drone from usa to india ,
and now i dont have an option of sending it for repair
2018-1-25
duke123
Flight distance : 78930 ft
I had the same problem with mine, I sent it back to DJI and they replaced it the gimble and the camera and no cost
2018-1-25
Bekaru Tree
South Africa
if you cant send the drone back for what ver reason then i may suggest you take compressed air and blow out the gimbal swivel parts (motors) - my thinking is that maybe there something sticking inside one f the grooves preventing its final operation to go horizontal - be aware that this assembley is very delicate so be very careful when blowing it out if that is what you decided to try.
2018-1-25
DJI Thor
Flight distance : 13602 ft
So the gimbal gets back to work if you manually rotate it to the center after powering the drone on, right? May I have a screenshot of your firmware info? I would like to have a check on it first. Thank you.
2018-1-25
iacajoreet
Flight distance : 38720 ft
This used to happen to mine many months ago, but later upgrades to the firmware and app fixed it. So make sure you are on recent versions.
2018-1-26
djiuser_60SseuO
India
2018-1-26
djiuser_60SseuO
India
2018-1-26
djiuser_60SseuO
India
iacajoreet Posted at 2018-1-26 00:19
did you have the exact problem mate?
2018-1-26
Locoman
Flight distance : 748675 ft
Do you have a filter installed on the camera
2018-1-26
damoUK
djiuser_60SseuO Posted at 2018-1-25 13:15
You can still send it for repair - if that's what DJI suggest - just that you might have to pay for it to be repaired!
2018-1-26
iacajoreet
djiuser_60SseuO Posted at 2018-1-26 01:47
Yes, the gimbal would sometimes go mad on start up and violently appear to bang against the sides, then come up with a gimble overload message. Then at other times it would do as yours is doing and just be at angle. A restart or two or a recalibration of the gimble would usually fix it. Then it stopped happening after one of the firmware / app updates sometime about mid last year.
2018-1-26
DJI Thor
Thank you for your update. For this situation, there might not be a way for users to fix permanently, you might need to send it back. Please contact our support to start a case. Here’s the link to contact us: http://www.dji.com/support
2018-1-28
