KedDK
Flight distance : 1133038 ft
Denmark
When i have changed my Photo/video settings, i tap the same icon to close as i used to open the settings, the odd lines/sliders down to the right.
If not done already, as i think you have done a update to the latest FW is try a refresh of both RC and AC,
if using Assistant 2 for the AC, first reset to factory defaults, unplug,, power down and remove the SD. Power up AC and reconnect to Assistant and do the FW refresh.
If still the same then i would try a downgrade to parent (1.04.0602) as above.
Remember to mount the SD again when finished ... |
