Can the X7 be attached to the M600?
4242 15 2018-1-26
CineView Media
Flight distance : 5365522 ft
Norway
If so, what flight times will you get from that?
2018-1-26
broadlandboy
Flight distance : 1654222 ft
Yes by bolting an I2 under it
2018-1-26
CineView Media
Norway
broadlandboy Posted at 2018-1-26 03:41
What kind of answer is that??
2018-1-26
HyperSpectral
Flight distance : 839160 ft
CineView Media Posted at 2018-1-26 03:44
he's being sarcastic because its well known some cameras rely on the inspire 2's internal processing to work and you didn't bother to go check yourself for the answer
2018-1-26
CineView Media
Norway
HyperSpectral Posted at 2018-1-26 07:31
Allot of helpful answers here, indeed.
I know its compatible with I2, but i dont know if its with M600, in fact, theres no info about it all, thats why im asking, and thats why we have these forums, cause if everyone already knew everything or everything was on Google then it would pointless, dont you think?
2018-1-26
HyperSpectral
CineView Media Posted at 2018-1-26 07:43
Check the FAQ for the X7 on the product page...
2018-1-26
CineView Media
Norway
HyperSpectral Posted at 2018-1-26 08:29
Thanks!!!!
2018-1-26
DJI Elektra
Sir, X7 can only be attached on I2. Thanks for your attention.
2018-1-26
ukaleq
Flight distance : 1303780 ft
Very helpful answers indeed...
For the record the X5S can be mounted on the M200 although it has no "RAW processing capabilities" either.
That means you cannot use it to record raw video but you can still use it for compressed video and for still pictures. Since there is also a gimbal to mount a X3, X5, etc. on a M600 your question was entirely legitimate.
That being said, why would you want to use the X7 on a M600 when you can use a real camera that has better image quality and that is not riddled with bugs?
2018-1-29
CineView Media
Norway
ukaleq Posted at 2018-1-29 10:01
Only for extended flight times
Are you saying the X7 has allot of bugs?
2018-1-29
ukaleq
No, I have no experience with that particular camera but I think pretty much all DJI products are full of bugs. I experienced this first hand with everything I bought from DJI...
2018-1-29
CineView Media
Norway
ukaleq Posted at 2018-1-29 16:11
Cant argue with that.
They should spend some time perfecting the current gear, rather than pushing out new versions of existing models...
2018-1-30
broadlandboy
The I2 & M200 series have v2 gimbal connector. Other drones have v1. Hence the need for an adapter to fit the Xt onto the M200 series & the addition of s to the camera models. You can not put a X5 onto either I2 or M200 series.
2018-1-30
ARCHITECTPHOTOG
Flight distance : 2730978 ft
Ok so what "real camera" are you suggesting be put on the M600 that you can control / change the functions of and has "better image quality" ?
2018-8-11
PITS Paul
I own a zenmuse X7, and can tell you the quality of pictures and film is superb, hard to believe a camera this small can produce such quality.  As far as bugs are concerned, the minor bugs it had in the beginning are gone, quickly solved by an update.
2018-9-2
divakar babu
India
dji matrice 600 pro (Red helium 8k its compatible)
2019-3-5
