Which Version Numbers are Right?
questech
Hello All,
I'm new here so forgive me for my lack of familiarity.
I have purchased a used Phantom 3 Professional and am in the process of updating all of the apps and firmware.  After updating everything as per the instructions I've found here and elsewhere I believe I have the latest updates.
However, I'm reading the "PHANTOM 3 PROFESSIONAL Release Notes" and I find a discrepency.
After everything is updated, successfully by all accounts and per the instructions), I go to the information about my versions in the "About" section of my DJI Go App, and I see that my app version is 3.1.26.
But in the above mentioned release notes it states:
"3. Requires the DJI GO iOS app v3.1.12 or later, or Android v3.1.6 or later, otherwise the flight is restricted
to a height of 30 m and distance of 50 m."
So I followed the instructions and by all accounts I should have the latest firmware loaded, but if I take the release notes at their word I have an older version and will be limited to a height of 30 m and distance of 50 m.
I know I must be missiong something...  What?
Thank you in advance for your support...  Anthony
2018-1-26
solentlife
Flight distance : 1087530 ft
Latvia
You are fine .... believe me - the worst for getting the numbers right is split between Forum Members and DJI themselves !!
3.1.26 GO on Android is latest.
Nigel
2018-1-26
questech
solentlife Posted at 2018-1-26 05:40
Thank you my friend!
2018-1-26
Hayden
After I upgraded to 3.1.26 App this morning the ipad will not longer connect to the controller.  I get a screen that says disconnected  , any ideas?
2018-1-29
ALABAMA
Flight distance : 10442687 ft
Reflash the firmware. and reinstall the app.
2018-1-29
Mark The Droner
Flight distance : 2917 ft
The app numbers can be confusing if you don't understand how they're numbered.
The numbers between the decimal points are whole numbers and count sequentially.  They're not in the normal decimal format like you might expect.
So... app version 3.1.6 should be read as "three point one point six."  You could say it's the sixth version of 3.1
app version 3.1.26 should be read as "three point one point twenty-six."  You could say it's the twenty-sixth version of 3.1
2018-1-30
Air/America
Hayden Posted at 2018-1-29 16:33
I don't know much, but I think that DJI GO 3.1.26 is to be used on an Android device.
RE: https://forum.dji.com/thread-131074-1-1.html
2018-1-31
