Mavic Pro Car Charger compatible with the Mavic Air Battery?
4912 3 2018-1-26
Romulus
Flight distance : 612608 ft
Hi!
Maybe someone have a answer to my question above? Can i use my Mavic Pro Car Charger also for the Mavic Air battery?
On the DJI website the two car chargers look very similar, only the power output is a little different and i can not see if the connector size for the battery is still the same.
Thank you for your Support.
Greetings
Roman
2018-1-26
AIister
Flight distance : 626647 ft
very similar specs but close up shows the battery connector is different.  i will say hard no.  pro charger would probably cook the small air battery with the extra current
2018-1-26
Roman, sorry to tell you that they are not compatible since the battery connector of Mavic Air is different.
2018-1-27
Romulus
DJI Mindy Posted at 2018-1-27 00:36
Hi Mindy!
Thank you very much for the information. That is very sad...
Greetings
2018-1-27
