Crystal sky not showing Bat %
1286 12 2018-1-26
Lenrage
Flight distance : 3031145 ft
Got the latest firmware installed on my spark and crystalsky.  The % on the battery remaining is not showing on the right corer.  it is like battery is at zero.
When I conect my iphone, the number shows........What is up with that
2018-1-26
StianGel
Flight distance : 686654 ft
Norway
You need to enable that setting in the Battery menu. (Almost top right corner.)
Some settings reset when updating the firmware.
2018-1-26
Lenrage, sorry to read on this, may I have the picture of the Battery Settings? Are all voltage normal?
2018-1-27
lannes
Flight distance : 4465 ft
Another poster "the mann58" had the same problem , as you can see from the thread we tried everything
https://forum.dji.com/thread-123010-1-1.html
It was resolved partially by a AC firmware upgrade to the P4P
2018-1-27
Lenrage
DJI Mindy Posted at 2018-1-27 00:33
this one is with my Iphone
2018-1-27
Lenrage
This one with CrystalSky
2018-1-27
TheMann58
Flight distance : 18669501 ft
This is a different issue than the one I was having with the Crystalsky (now completely resolved) where my P4Pro and P4 aircraft battery level would constantly read "0%". The most recent firmware updates for both the P4Pro and the P4 addressed that issue and I can now see actual aircraft battery % (and voltage) on the Crystalsky camera screen
Your Crystalsky is showing "N/A" both for aircraft battery level and GPS.  Can you move the gimbal up an down with the gimbal wheel?  If not, then your Crystalsky is not actually linked to your P4Pro.
2018-1-27
Wachtberger
Flight distance : 261509 ft
My guess is that you are using an OTG cable. This is currently not supported by GO 4 for the Spark. It is not a Crystalsky issue but a GO 4 issue in the Android version.
2018-1-28
Lenrage
Wachtberger Posted at 2018-1-28 07:47
I am using a DJI OTG Cable
2018-1-28
lannes
Lenrage Posted at 2018-1-28 15:50
Yes , that is the OTG telemetry issue with the Spark, DJI has disabled the OTG capability of the Spark RC
Try connecting the CS via wi-fi to the Spark RC everything should be fine after this.
2018-1-28
Thanks for the picture, could you please try lannes's suggestion and connect CrystalSky to Spark via WIFI?
2018-1-29
bety
Flight distance : 1097644 ft
Vietnam
Hello.
Impossible to connect Spark in WiFi on CrystalSky 5.5
Message:  Not in range
https://servimg.com/view/19069836/91
2018-2-6
Wachtberger
bety Posted at 2018-2-6 01:54
Hello.
For me it works well, but I have no idea what could be the problem with yours.
2018-2-6
