I have Phantom 4 Advanced for a week now, and it have vibration that makes jelly effect on my videos.
Here is the video from today:
If i press this part, vibrations stops.
Vibrations are comming from gimbal since i have them when my drone is stationary with engines off, also when in the air without motion. If i tilt it forward it stops.
All of this is making me beleave that it is software related and that gimbal motors are trying to compensate for something nonexisting, since when on flat table, there is no stress on gimbal.
Also, it produces this sound when tilting:
What was done during this problem:
Refreshed firmware (latest)
Factory reset
Calibration of everything
Adding coins to balance the camera (a desperate attempt)
I bought this drone in foreign country so i cant take it back so easly. I hope there is beta firmware as there is for PRO version or at least way to downgrade to some other version since i dont have option to do so. Also DJI Assistant 2 is not giving me any firmware, so if i need to update i do it over DJI app on android.
The gimbal system is a system all on its own, and is using servo circuits to perform the stabilisation. These circuits had adjustments to set them up and DJI do not give you access to those settings. Therefore the only way to cure this is to send the aircraft back to DJI for adjustment.
Geebax Posted at 2018-1-26 14:19
But these values surely can be changed in firmware update
Geebax Posted at 2018-1-26 14:44
No, they cannot, because the value can be different for every different aircraft system, so there is no universal value.
I have phone gimbal, and it is set for univeral values, since i can switch diferent phones with it, surely gimbal for phantom is set the same way...
For this case i think some value is set to too much sensitivity, since shock absorbers are the ones that are variable on phantoms, cameras and gimbals are the same. I've seen some people compaining on this and beta firmware solved them problem.
Goran_m_pg Posted at 2018-1-26 15:26
I had this same problem on a P4P that rapidly became worse until the camera would buzz loudly even when sitting still. I sent it in for repair and it ended up being a bad camera control board.
Updated to this beta and problem was not solved. Is there anythig else i can do before returning it back?
I must say that i'm disapointed in this product considering its price range. For this money i expected premium product, not the product that i will be left without for a month right after purchase since they need to send it to Germany for repairs.
DJI Thor Posted at 2018-1-26 20:51
Hi there, I had forwarded the beta firmware for Phantom 4 Adv gimbal noise issue, please check for the update and see if it works for you. Thanks.
Hello, i have same problem on P4A. Can you help me ?. Thank !
My 4 adv gimbal sounds like a helicopter taking off. I calibrated it yesterday since it wasnt straight and that took almost 2h, now camera is straight at least but the noise is still as loud as before, if i touch the gimbal the noise stops and i feel it vibrate.
Tjabo99 Posted at 8-1 21:06
Read this thread, the answer has been given. You have to send it to DJI for repair.
I have the same problem here with noise and tilted horizon. No crashes, but the problem exists. Can you please send me the beta, please! My mail is: vania_gff@abv.bg
