U.K. Flyer buying in US
1684 13 2018-1-27
fans665a76ad
Flight distance : 20 ft
Heading over to Miami from the UK in March and with the current exchange rate the Mavic Air is almost 50% cheaper in the States than the U.K. Can anyone foresee any problems in terms of warranty etc? I appreciate the charger plug will be different but I can put up with that for a £300 saving!
2018-1-27
RocketChap
Flight distance : 902034 ft
Yes there is only a regional warrantee - e.g. see https://forum.dji.com/thread-131054-1-1.html
2018-1-27
RocketChap
Yes there is only a regional warrantee - e.g. see Forum
2018-1-27
Rodpods1604
Import tax when returning to the UK
2018-1-27
fans665a76ad
So basically, if there was a warranty issue I'd have to send it back to The States rather than Holland.
2018-1-27
Howdy2u2
Flight distance : 1886 ft
Yes that is correct. Your $300 savings could end up costing you more along with headaches if needing repairs. Since you would need a physical address to send it from in the states/ and back to in the states. Then get it sent back to you in your country.
2018-1-27
Wirezfree
Flight distance : 17999 ft
Duty from "Outside EU" scroll down... depends on value
2018-1-27
fans665a76ad
So if I was an American living in the U.K. with my drone and I had a problem, dji would insist I sent to the States. Couldn’t I send to China?
2018-1-27
RocketChap
fans665a76ad Posted at 2018-1-27 06:05
In addition to Duty (which is usually only a few percent) you may have to pay 20% VAT on the entire value - see https://www.gov.uk/duty-free-goods/arrivals-from-outside-the-eu.
2018-1-27
RocketChap
I wondered if one of the DJI folk would like to explain why the Mavic Air is almost 50% cheaper in the US than the UK - since its manufactured in China.  Are the tariffs really that different - is the cost of support  in Europe really that much more.
2018-1-27
Wirezfree
RocketChap Posted at 2018-1-27 15:56
There is clearly something odd..??
Say for example it was 5000 YUAN in China
Current exchange rates give:
@ $791
@ £559
Checking $791 in GBP is £558 so almost the same
So it looks like the UK is really marked up by somebody.?
Are you sure it's exact like for like you have seen in US.?
2018-1-27
fans665a76ad
It’s definately the same drones. Large multi national companies often rip Brits off by charging almost the same amount of dollars as pounds despite the current exchange rate being 1.40. It’s only recently the exchange rate has got better and is worth considering. Looking forward to hearing DJI response regarding the warranty
2018-1-27
fans665a76ad
Can someone from DJI confirm the warranty issue please. I have read that if I take out Refresh the warranty is effectively worldwide
2018-2-9
fans665a76ad
Anyone from DJI care to comment please
2018-2-16
