hallmark007
Flight distance : 9827923 ft
Looking at your log , it looks like you picked up some compass problems I think this may have happened from the ground you took off from was it concrete?, you were also flying very low in tripod mode you could have picked up compass problems flying over metal objects, you received compass warnings and really should have landed at this point.
You continued on receiving yaw errors before going into Atti mode and although Aircraft can be controlled in Atti mode it can be difficult, it looks twords the end of your flight you may have clipped branch of a tree which caused your spark to fall out of the sky.
I think your envoirment was the cause of your crash oblivious magnetic interference causing compass problems, having said this, I have seen dji give warranty in such cases, I would advise you to sync your flight in your app contact dji and set up a case for warranty or repair, just contact support and they will take care of the rest, sending you a case number and arranging for a pick up of your spark.
I wish you luck and hope it’s a good outcome for you. Good luck. |
