PowerBand1
djiuser_iGJqCoT Posted at 2018-1-28 18:27
I purchased one from Amazon, but I am fairly certain that they are the same. The paint doesn't quite match and the paint was not perfect in a few spots, otherwise it fit just fine. The biggest thing to realize is that the screws on the gimbal are terrible, and will strip very easily. If the yaw motor screws strip, as they did for me, they are recessed and pretty much impossible to get to. And, no, drilling the screw out will not work. Same for a screw-removal kit. Those cheap screws cost me a whole new yaw motor and a screw kit, as well as the time for swapping motor caps. In the end, a $20 swap ended up costing me almost $100.
Hi there mate...I can relate to your post doing a yaw arm repair on P4, I too cannot remove the yaw arm motor because of those damn crappy screws (stripped)...looks like i up for a new yaw motor..where did you get that screw set from? |
