RC bracket size
844 9 2018-1-28
hobbydroner
Belgium
Hi guys, I was thinking to upgrade from spark to mavic air but my only concern is can I put my mini IPAD 4 into the RC,will it fit? I read that the RC s bracket can open up to max 16 cm ,Mini IPAD4 is 20cm ! What you guys think about it ? Appreciate replies.
2018-1-28
hallmark007
Flight distance : 9827923 ft
I’ve seen a video that shows it will fit but not as securely as with spark, there are many different systems you can purchase that will help you with iPad mini"
2018-1-28
hobbydroner
Belgium
hallmark007 Posted at 2018-1-28 04:09
Thank you for that info.
2018-1-28
DJI Elektra
Hi, there. Here is the spec for your reference:
Max length: 160 mm  Supported Thickness: 6.5-8.5 m
Thanks for your support.
2018-2-4
Buzzyone
Flight distance : 4647913 ft
The iPad Mini 4 fits into the controller arms, no problem, it is a bit loose as the arms cut out is larger than the spark, but it cant fall out.
2018-2-4
Bigplumbs
Flight distance : 620164 ft
Both Ipad mini 3 and mini 4 will fit fine. You do need to learn the best way of fitting it in.
2018-2-5
hobbydroner
Belgium
Bigplumbs Posted at 2018-2-5 00:41
Thank you for the info.
2018-2-5
hobbydroner
Belgium
Buzzyone Posted at 2018-2-4 21:23
Merci beaucoup.
2018-2-5
hobbydroner
Belgium
DJI Elektra Posted at 2018-2-4 20:24
Hello, I read somewhere about those 160mm max length and made me a bit worry to get my mini Ipad 4 into the controller since the lengh of mini 4 is around 20 cm. but a lot of replies on my topic and kind of  relief to know it will fit. But still waiting a little to see other reviews about the mavic air before I buy it. Thanks for the info.
2018-2-5
DJI Elektra
hobbydroner Posted at 2018-2-5 11:27
You are welcome. Hope users in the forum can give you the best advice.
2018-2-10
