dencio1976
Flight distance : 10397 ft
Philippines
DJI Tony Posted at 12-16 14:42
Hi, thanks for the inquiry. I would recommend checking the performance of the aircraft to see if there will be a problem before buying it. It would be better if we could determine if the aircraft was repaired before and check the warranty as well. Thank you for the support.
I did plan on buying a 2nd hand spark before but opted to buy a bnew one instead. This post has me more convinced I did the right decision. Though yeah, if you know what to check when buying a 2nd hand drone then you're good. But this post has made me think twice about the flight record you'll be sharing around as it isn't username attached but rather ac attached. That could be an issue for me if I bought 1 2nd hand. I wouldn't want somebody else's flight record on mine. Even more so when I decide to sell it and say get the Spark 2 when it comes out. |
