tony_bish
Hi Thank you for your response...I was able to get it calibrated after I changed some settings in my Futaba remote (End to 80 and Travel to 100) found on the following posting:
http://forum.dji.com/forum.php?m ... p;tid=9672#lastpost
I successfully calibrated the device twice...Then came the very short flight...
After calibration, I tested most of everything: Gimbal controls, Gear, ETC and the GPS/Attitude was cycling correctly.
The remote was on manual mode for takeoff and I started the props and began to throttle up...About 10 feet, the GPS light turned blue ( if anyone knows what caused this I do not know, first time with spreading wings equipment and A2) It quickly drifted right and flipped over hard, really hard (I still had the throttle on). The drone is...not in the greatest shape...but should be fine with some work
First, any suggestions why this could have happened? That was my first time operating that type of drone, so it may have been setup or operating error? However it seemed really out of whack, it completely lost control without me touching any controls (besides throttle up).
Also, any suggestions on warranty, repair, parts and accessories etc...
S900---5 of 6 Frames, motors, and wiring good. 6 broken propellers ( already have extras)
1 landing gear leg broken
Center Board, all good except one small chunk out of it, I can't see it effecting anything
A2, LightBridge, and IOSD appear fine
There are a few torn can cables and such.
Month old Zenmuse Z15-GH4 Gimbal---Servo 1 and 2 good...Servo 3 took a blow and does not rotate well...repair?
GH4 camera and lens----Good, things a tank
Spent lots of time preparing it, to bad it ended on its backside but it should be repairable
Any suggestions are appreciated! |
