INSPIRE 1 SHAKEY VIDEO
621 15 2018-1-28
fansdc7c537a
Hello I bought an Inspire 1 Yesterday and I flew it for the first time today. The video is unbelievably shakey. I dont know why its doing this. It was windy out when i flew it but the drone weighs very heavy and the stabilizer should not allow this to happen. Here is a video of it    ANY HELP? thanks
2018-1-28
TruGreen
Flight distance : 621909 ft
check all 4 motors for any wiggle/wobble. if so tighten the 4 screws under them. also check your props for any dings, dents, bends, chips, cracks
2018-1-28
UP Films
Flight distance : 81683 ft
try and check the gimbal dampers. restarting the camera through the go app, and checking the gimbal vibration board for any abnormalities.
2018-1-28
Farnk666
Flight distance : 1711394 ft
Does it do it in flight as well as a hover?
2018-1-28
fansdc7c537a
Farnk666 Posted at 2018-1-28 19:44
its just random throughout the flight. sometimes its stable, sometimes it shakes violently
2018-1-28
fansdc7c537a
UP Films Posted at 2018-1-28 16:48
where do i check the gimbal dampers? and the gimbal vibration board? thanks
2018-1-28
TruGreen
fansdc7c537a Posted at 2018-1-28 20:07
the gimbal dampers are the little black rubber things holding the vibration board, which the camera attaches too
2018-1-28
fansd845e849
Flight distance : 1495906 ft
I had this problem on 1 side of the inspire 1 when I first acquired it.
I just tightened the 4 screws on 1 arm clamp on the side. One side had loose screws and made it vibrate a lot.
2018-1-28
Donnie - Apple 0
Flight distance : 3636782 ft
Does it do this if the AC is stationary ?  Test it like that once , also as the others say check that the camera is mounted correctly and nothing is loose.  It should NOT do this .
How windy was it by the way and did you do a gimabal calibrtation ??
good luck
donnie
2018-1-29
mixchief
Flight distance : 182057 ft
looks just like I just had during my trip. I tightened all motor screws and changed the props ( I was using high altitude props I just bought from DJI as I was at 8000 feet ASL) and my first test was without that jello and I was flying in 15-20 mph sustained 30-40 mph gusts. All is well.
2018-1-29
Luxury Vue 7
Donnie - Apple 0 Posted at 2018-1-29 04:28
yea i did a gimbal recalibration, I am gonna go out and buy the right screw drivers so i can tighten some of the screws around the aircraft. I flew again today and it seems like it only shakes violently in 4k with 30/20 fps and on 1080p it doesn't shake as bad, but still present. It only shakes when the RC is in the air/
2018-1-29
TruGreen
Luxury Vue 7 Posted at 2018-1-29 14:58
2mm allen is what you need for the screws
2018-1-29
fansd845e849
Philippines
The inspire 1 accesories come with the allen to tighten motors and arm screws
2018-1-29
Donnie - Apple 0
Make sure your SD card is fast and within the specs.  Some of the cheaper ones won't cut the mustard.
donnie
2018-1-30
Luxury Vue 7
Donnie - Apple 0 Posted at 2018-1-30 04:27
donnie
Will that really make the camera like that shake? what does a slower sd card do, and do you have any recommendations on fast sd cards 128gb+? thanks
2018-1-30
Donnie - Apple 0
Luxury Vue 7 Posted at 2018-1-30 13:33
Just think if it was a slow card may cause the problem not sure , could have been the winds at ground level were high but at altitude were outrageous.  ( that is how I once flew 93 mph downwind once )
Micro SD
Max capacity: 64 GB. Class 10 or UHS-1 rating required.
donnie
2018-1-31
