V1.2.1.0 Problems
7068 11 2015-4-26
joe.montalto13
Flight distance : 1686007 ft
I just got my DJI inspire last night. I was updating the firmware but i accidently turned it off in the middle of the update. Now I cant update the AC at all i just keep getting a continuous beep and in my .txt LOG file i get this:
[00010330]Version checking[1]...
[00010335][01 00] v1.7.2499 -> v1.7.2499
[00010340][01 01] v1.7.2499 -> v1.7.2499
[00010369][03 05] v34.1.0.5 -> v34.1.0.5
[00010416][03 06] v2.0.5.10 -> v2.0.5.10
[00010428][04 00] v1.16.0.76 -> v1.16.0.76
[00010469][05 00] v2.5.6.1 -> v2.5.6.1
[00010481][08 00] v1.11.0.19 -> v1.11.0.19
[00010500][09 00] v1.7.0.3 -> v1.7.0.3
[00010529][11 00] v3.3.0.0 -> v3.2.1.0
[00010589][12 00] v1.3.0.60 -> v1.3.0.60
[00010629][12 01] v1.3.0.60 -> v1.3.0.60
[00010689][12 02] v1.3.0.60 -> v1.3.0.60
[00010749][12 03] v1.3.0.60 -> v1.3.0.60
[00010813][15 00] v1.1.2.0 -> v1.1.2.0
[00010849][17 00] v1.1.0.1 -> v1.1.0.1
[00023354][17 01] device not detected.
[00023373][19 00] v1.0.8.59 -> v1.0.8.59
[00023378]Packet upgrade failed at version checking.
I also can not set my RC as my return to home i keep getting "Signal to weak" and i also can not put it in to travel mode. The 24 hour online help said i have to call DJI tomorrow. anyone have any fixes for this?
Also in my Pilot APP under about this is all that is shown:
Version
APP: Version 1.0.3
Firmware: Version 1.2.1.0
Contact
Website www.dji.com>
2015-4-26
chibberts
Try taking the card out and starting up the AC and RC and go through some stick movements. I would do it with the props off. Get the motors spinning and then if all works put card back in and try update again. If on that attempt the update fails (constant beep) just remove update from card, but try to update RC first and you should be able to fly without any issues as long as update is not on card in AC. This worked for me. DJI support had me do it and seems to be fine.
2015-4-26
joe.montalto13
I am able to fly it but it won't update and won't return to travel mode.
2015-4-26
joe.montalto13
Just tried again still content beep!!! AHHHHHH!
2015-4-26
PeteGould
If it is BRAND NEW and you have a free return period through the dealer, I suggest a return and exchange.  Because the alternative is likely a shipment to DJI and a four to six week turnaround time for repair.
2015-4-26
guewald
Flight distance : 314888 ft
Brazil
Tahoe_Ed Posted at 2015-4-27 13:41
Please format a SD card and install the attached bin:
What does this specific bin file?
2015-6-12
Tahoe_Ed
Flight distance : 2605 ft
guewald@hotmail Posted at 2015-6-12 20:50
Corrects the .17 issue that he was having.
2015-6-12
info.digitalvid
Hi i have same problem with my phantom 3 pro, no video camera signalthe camera capture ok, record ok, gimbal ok, drone is ok, but no video camera signal in the tablet, ( my tablet is nvidia shield) i try with note 4, lgg3 and no video.
i need reset device not detected.
Please can you help me?
thanks
[00012655]========== 2014.01.01 00:00:12 unsynchronized ======
[00012737]Packet [C:\P3X_FW_V01.01.0009.bin] detected.
[00012817]Packet upgrade start...
[00012878]Packet checking...
[00012893]Done.
[00012901]Version checking[1]...
[00012941][03 05] v34.2.0.8 -> v34.2.0.8
[00012981][03 06] v2.1.6.18 -> v2.1.6.18
[00012993][04 00] v1.36.0.0 -> v1.36.0.0
[00013021][09 00] v1.7.0.3 -> v1.7.0.3
[00013101][11 00] v1.6.0.0 -> v1.6.0.0
[00013157][12 00] v1.8.0.0 -> v1.8.0.0
[00013210][12 01] v1.8.0.0 -> v1.8.0.0
[00013275][12 02] v1.8.0.0 -> v1.8.0.0
[00013330][12 03] v1.8.0.0 -> v1.8.0.0
[00025846][15 00] device not detected.
[00025910][17 00] v1.1.1.2 -> v1.1.1.2
[00026010][17 01] v1.0.2.4 -> v1.0.2.4
[00026041][19 00] v1.0.8.59 -> v1.0.8.59
[00026049][01 00] v1.6.2736 -> v1.6.2736
[00026056][01 01] v1.5.2735 -> v1.5.2735
[00038565][08 00] device not detected.
[00038571]Packet upgrade failed at version checking.
I need reset theses mod 5 and 8. can you make me a bin file for reset it.
Thanks
2015-6-17
info.digitalvid
Tahoe_Ed Posted at 2015-6-13 02:38
[00012893]Done.
I need reset theses mod 15 and 8. can you make me a bin file for reset it.
Thanks
2015-6-17
Tahoe_Ed
That is saying that your air end decoder on the camera and MC decoder are not detected.  Please check your connections on the camera to the craft.  Then try again with a freshly formatted SD care and the bin file loaded.
2015-6-17
info.digitalvid
Tahoe_Ed Posted at 2015-6-18 06:00
That is saying that your air end decoder on the camera and MC decoder are not detected.  Please chec ...
Can you tell me what those wires? I reviewed the gray wires to the sensor and drone, and seem fine , I have also reviewed ribbon cables going to the engines, the well stabilized gimbal working properly .
2015-6-29
Tahoe_Ed
info.digitalvid Posted at 2015-6-29 21:15
Can you tell me what those wires? I reviewed the gray wires to the sensor and drone, and seem fine ...
You could have a defective camera if all the connections are correct.  That would require a call to DJI for Replacement or Repair.
2015-7-5
