Tom_A
Flight distance : 899951 ft
For watching TV, yeah 4K does seem like a bit much. Even someone with really good eyesight can't see a difference when sitting at a reasonable distance.
Here is why you shouldn't use that same logic for recording video:
When you record at 4k, you have the option of zooming in without losing quality if your end result is going to be 1080p. Even though hardware stabilization has gotten really good, you can occasionally end up with a clip that could use some software stabilization. This can especially be the case with the Spark since it does not have a 3 axis gimbal. What if you end up with something showing in your video that you would like to crop out? With 4k, you have a little bit of resizing to work with that will not lower the end result quality.
There's this interesting vertigo effect you can do by zooming in on a subject while you move the drone away from the subject. You can do this with 1080p, but the video quality difference will be noticeable as you zoom in using editing software.
Then there's all the other camera setting choices not available on the Spark. You'll be able to do slow motion video, 24fps if you prefer that, and the new quick shots are really nice.
Panorama seem to shoot quicker on the Mavic Air. You get a little more flight time than the Spark, but not as much as the Mavic Pro, or Pro Platinum.
I have a Spark and I don't intend to sell it although I just purchased the Mavic Air, but if I was looking at buying just one now and had the money for the Mavic Air, that is what I would get.
