Nigel_
Flight distance : 388642 ft
There is only one sensible angle to set it to on a drone, and that is perfectly vertical so that it blocks all horizontally polarised light. Reflections off water are always horizontally polarised (doesn't matter where the sun is). The amount they are polarised by varies with angle, so having set the polariser to vertical, you then need to adjust the drone's height to get the best angle to remove the reflections, roughly 45 degrees, or if you want to be technical look up Brewsters Angle and note that the exact figure depends on the type of water and on how flat the water is!
If you are trying to affect the sky rather than water reflections then there isn't a good angle to choose since that will depend on where the sun is relative to the drone, but again on average, vertical is likely to give a more balanced image than other angles.
If you are trying to affect the grass, then vertical is probably best, although it wont have much affect unless you are looking towards the sun, and then you probably wont have a good image anyway.
The easiest way to set the polariser to vertical, if vertical is not marked, is to put the drone in front of an LCD TV and set it so that the TV image is completely blocked when the TV is rotated 90 degrees. (Normally you would rotate the camera 90 degrees but that doesn't work on a Phantom due to the gimbal!) You can also look through it by eye and then mark the vertical position rather than turn your TV on its side, but make sure you look through it from the camera side, not from the front. Note that it must be a normal TV and not a 3D TV, computer monitors are often polarised the wrong way and tablets and phones are normally polarised at 45 degrees in one direction or the other. Also note that even if the polariser does have a factory mark on it, the mark is often placed randomly rather than at the vertical point so best to check and put your own mark in the right place. If you are not sure about your TV or want to use a monitor then check it with polarised sunglasses, they are always polarised vertically for the same reasons you want to set your filter to vertical, you want your filter to have the same effect as the sunglasses. Note that TVs are always polarised vertically so that you can see them properly while wearing polarised glasses, phones and tablets are at 45 degrees so that you can use them horizontally or vertically while wearing sunglasses, although they will only be at half brightness either way. |
