Buzzyone
Flight distance : 4647913 ft
Welsh Mavic Posted at 2018-2-5 09:42
Thanks had a look on the net , seems the whole arm is available for 35 euro but it seems I can just replace the leg strutt at a fraction of cost. Should be about 2 euro or something.
There just seems to be 3 connection screws that are so small and fine I cannot see if they are rivets, allen or hex key or a type of Phillips screw etc can anyone verify if it is just a leg strut needed.
Screws are Hex 1.5mm when you take the leg off, the antenna will slide out, simple fix, just note where the antenna slides into the leg.
Replacing the arm will require some soldering skills, along with opening up the drone = no warranty. |
