Mavic Air APAS and Activetrack
5394 11 2018-1-29
Airwater
Flight distance : 1517057 ft
Can anyone tell me if APAS works within Activetrack? And does it work going both backwards and also forwards? The demos I have seen have only shown it working when being manually operated with the controller which seems like a limited implementation because it would be most useful in Activetrack.
2018-1-29
hallmark007
Flight distance : 9827923 ft
This might help.
2018-1-29
QuadKid
Flight distance : 482349 ft
WOW! I can't believe DJI released this without a full users guide, only a quick start. Amazing!
2018-1-29
Airwater
So it doesn't work in the mode it would be most useful - activetrack. So it's only for manual control, not very useful then.
So when it is following me in active track and a tree gets between me and the drone, it will still just stop and fall out of activetrack like the Mavic Pro?
2018-1-29
Airwater
OK I found out that APAS can be enabled within DJI GO 4 to work within Activetrack but it is not enabled by default.
2018-2-1
A CW
Flight distance : 13926112 ft
That’s odd as the Mavic Pro uses this feature in both active track and tap fly
2018-2-1
dragonir
Hi,
does active track works while skiing downhill?
Mavic pro doesn't work while skiing downhill
2018-2-1
Tadango
Flight distance : 232359 ft
NO downhill does not work.
2018-2-1
dragonir
Thanks
This is a pity , because I#m searching for a Drone where it works
2018-2-1
Tadango
Ski uphill and playback in reverse
2018-2-1
fans84ae0a03
Flight distance : 616598 ft
A CW Posted at 2018-2-1 01:55
APAS isn't available on the Mavic Pro.  Unless they added it later.
2018-3-11
A CW
fans84ae0a03 Posted at 2018-3-11 10:32
APAS isn't but there is the option in the app for the Mavic Pro to move backwards or around objects that it senses when using active track and tap fly - this feature has been built into the software of the MP for about a year now.
2018-3-11
