Texas-Mark
Flight distance : 23002 ft
New Phantom 3 standard owner here with a few questions.
1. Is there a search function on this forum? If there is one, I can't seem to find it.
2. I have downloaded what I believe is the latest user manual, but it still seems out of date with some of the functions. Is there somewhere to find the most up to date directions? See #3 below.
3. Not so much a question as much as a gripe. I have been messing around with the Home Lock function and had a heck of a time figuring out how to make it work. I already had multi flight mode enabled, but flipping S1 down did not cause a pop-up to appear as I had read. So then after some more searching, I saw that you had to first select the IOC menu. Well that was not where I read it was either. I finally found that it is located under the RTH icon. Then the first time I selected it, I got a pop-up that I had to acknowledge blah, blah, blah. Good thing I was just doing a test flight, and did not need to do this in a rush. Then I had to select the Home Lock option, Then I had to apply that. Just seems to me to be way to many steps to actually turn it on. At a minimum flipping the switch should pop up the options. And selecting one of those options should not require another press to apply what you just selected. |
