fans773350f4
DJI Mindy Posted at 2018-1-29 23:31
Hi Rob, we are so sorry for the difficulties you are experiencing now, the original footage is saved in the SD card and the issue you are having is the image transmission, what mobile device are you using? Is it with strong decoding ability? Have you checked the image transmission outside just in case the signal is interrupted? Besides, have you tried to flash the firmware again to see if the issue persists?
As for the propeller charge, may I have the previous case number? So that I can check more details for better support. Thank you.
Hi Mindy thanks for writing me back.
The device i am using is a Samsung Galaxy tablet. I'm not sure what you are asking about when you ask about "checking the image transmission outside". I've only flown the Mavic outside.
The problem occurred right after updating the firmware so it was up to date at the time. I had thought about trying to roll it back to a previous version or even resetting back to factory but when I researched how to do so the folks online said it was a bad idea and suggested that if that was actually needed to leave it to the techs at DJI to do. That's when I called in and started the support process.
The case was CAS-1371635-G7K7T4.
At this point I had given up and used my DJI care. Thanks for taking a look.
Item Quantity Unit Price(USD) Total Price(USD)
Mavic 8330 Quick-release Folding Propellers 2 9.00 18.00
Gimbal and Camera Module 1 101.00 101.00
Repair Service Fee 2 65.00/H 130.00
Freight: 0.00
Total Amount: 79.00
Total Payment: 79.00
Rob |
