GermanPilot
If you are interested in the German "Drohnen Plakette" then please read this post:
https://translate.google.com/tra ... ketten%2F&sandbox=1
Original Site (in german): https://versichertedrohne.de/blog/drohnen-plaketten/
Translation:
Annoying, but mandatory - badges for drones
The first month with the new drone regulation is already over and yet there are still many questions here and there. A major issue is the labelling requirement and thus the question of how best to label my drone with all the necessary information.
All drones need a UAV license plate already from 250 grams take-off weight. It makes absolutely no difference whether the copter is used commercially or only privately, there is no exception for the use on model airfields. The marking must be durable and fireproof
The law stipulates how such a drones sticker must be designed. A simple sticker is definitely not enough. The label must not only be permanently attached to the copter, but must also have fireproof properties. Plaques made of plastics are thus sometimes ruled out. Aluminium drone stickers are ideal. Since plastic badges or stickers do not meet legal requirements, they must be metal badges. These are definitely fireproof.
Metals, however, can considerably disturb the sensitive electronics of a quadrocopter, such as the DJI Phantom, and the weight of the badge itself should not be underestimated. Therefore, aluminium drone stickers are perfectly suited. Aluminium is not only extremely light and yet fireproof, it also does not interfere with the sensitive electronics of the copter. It is also crucial, however, that the marking on the sticker itself is fireproof. Therefore, the sticker should be engraved with the necessary information. Even after a battery fire, at which extreme temperatures are reached, it can be guaranteed that the marking is still decipherable.
What information must the sticker actually contain?
Now the sticker should be large enough to contain all the information required by the drone regulation. In addition to the full name of the owner, the address must also appear on the drones badge. It can also be useful to have the telephone or mobile number engraved into the aluminium. This makes it easier and quicker to reach the owner if the expensive quadrocopter should ever fall out of the sky.
Hope it helps!
Best Regards,
GermanPilot |
