dronybaloney
Flight distance : 24897940 ft
Once again i am reporting the lousy videofeed of the p4p
Since after the dji go app update .15 the image transmission is very bad . What are you going to do about this.
I also own mavic pro and all is fine .
I updated everything to the latest update /firmware i am using ipad mini 4 , compleet bad with interruption and often signal lost ( doing the same route and area with the mavic: no problem). Also use iphone x , a little bit less bad transmission , but still some. Yes i know all the suggestions you already gave in the past: shut down all other apps, turmoff bluetooth, airplane mode, 2.4 ghz etc etc . But once again i reported this before , but still no sollutions.
So what is the hell is going on. Are you working on this ,i see more persons have same problems on the forum , or are you tooooooo busy with promoting or busy with the mavic air , and forgettng about the phantom users.
Maybe its time to create a different app for each series.
Anyway is your engineering department working on this? Or at least are aware of this? |
