what sd card tshould I buy
1301 4 2018-1-30
Lino Miguel Abreu
Flight distance : 64160 ft
Portugal
Hi there
Just ordered my mavic pro, can't wait to get my hands on it!
Is there a minimum writing speed i should consider for buying an sd card for it? What about capacity, I'm planing on getting an extra battery, what do you recommend?
Thanks!
2018-1-30
Brian88
Flight distance : 385942 ft
Considering Lexar doesn't make cards anymore, Sandisk is your best bet as far as brands go. You want a class 10, U3. Size is up to you. I'd go with at least a 64gb personally. But you can get away with smaller ones.
2018-1-30
DEUCEDOG
Flight distance : 2501575 ft
Brian88 Posted at 2018-1-30 14:02
Yep.. Sandisk extreme is the way forward , be sure to buy from a good retailer to avoid counterfeits
2018-1-30
Lino Miguel Abreu
Portugal
Thanks.
i'm considering using only two batteries, so recording in maximum definition and for, say, 15 min each, what capacity do I need for the 30 min recording expected?
2018-1-30
DJI Thor
Flight distance : 13602 ft
Hi, we suggest using SD card with Class 10/UHS-1 and above and writing speed with 60Mbps. Please kindly choose original SD card from the SD card company, which can ensure the full test of its stability and compatibility.
And for the time of recording, here is an example for calculating the speed (reference only):
A 16 GB card, 4K/1080P 60fps - 60Mbps = 36mins
60 Mbit/s ÷ 8 × 60 = 450M Byte/min  16 GByte/450 MByte = 36 mins. Hope it helps. SD.png
2018-1-30
