TruGreen
Flight distance : 621909 ft
djiuser_iGRC1D8OlpDl Posted at 2018-1-30 19:34
Thanks for the offer, I will probably take you up on it, how do I determine exact model? I see the different models listed on certain parts and certainly do not intend to order the parts for the wrong version. My concern would even extend to the tiny screws and such. what parts to lube, if any, extend of what parts need properly cleaned, etc. The gift of this to me lead me to the web and facebook, wow, what a hobby this is.
you have two version both of which are identical for almost every part but heres the break down
Version 1:
will have a camo style carbon fiber pattern on the arms
says Inspire 1 model: T600 in the bottom of battery tray
has smaller X3 vibration board
FCC ID also on bottom of battery tray will end with 1410
Version 2:
will have the more traditional woven carbon fiber pattern on arms. (very early V2 had camo still)
says Inspire 1 V2.0 model T601 in bottom of battery tray ( very early V2 said T600)
has the bigger X5 vibration board ( extends out past the edges of under body)
FCC ID in battery tray ends with 1510 ( very early V2 still had 1410)
the motors will have 3510H printed on the top
besides those the bodys, and everything else is the same between the two. also for cleaning and lube only the center worm gear that lifts and lowers the legs is all to really maintain with lube |
