Simmo1
Flight distance : 1624 ft
Snipped from another forum...
Once you have it, you just need to add the specs into a separate table in your ops manual like you did for your Inspire including MTOM (which is unbelievably 784g!!!!) - serial number and all the usual etc etc. You then need to make specific checklists pertinent to that aircraft together with the appropriate emergency procedures (if they are different to your Inspire). Then make a revision note of your ops manual (v3 or v4 or whatever) and you do not need to submit until your next SRG 1320 renewal with the CAA. You will also need to make a note that only one UAV will be airborne at any one time (assuming that's the case) and you will need to add the aircraft to your fleet with your insurance company. Job done! |
