Spark turning slightly during flight
796 4 2018-1-31
Nikp
Flight distance : 123947 ft
South Africa
Since the past few flights I have noticed that the spark turns very slightly to one side (which one I forget).
When I fly in a straight line back and forth, I don’t not arrive on the same position again. It is not a constant turning though, or st least I don’t think so.
Is this a calibration thing or could it be something else?
2018-1-31
jimm00re
Flight distance : 1277503 ft
You suspect correctly, calibrate your sticks.
2018-1-31
Nikp
South Africa
Ah ok, i haven’t done a Stick calibration yet, only imu and compass..
Thanks for that Tipp. Will try it next
2018-1-31
DJI Elektra
Nikp Posted at 2018-1-31 09:03
Nikp, if the problem remains, please check if there is any interference around your spark and you can export the flight data and the black box data for further analysis.
2018-1-31
S.J
Flight distance : 322454 ft
India
very rarely you do a stick calibration.
such movements are bound to happen due to various reasons including pilot movements
2018-2-1
