fansc5ce4b29
Flight distance : 176312 ft
Same thing here. Not sure why DJI designed the port this way, but I'm sure plenty people will break the controller port because of this bad design.
The port is actually a normal micro USB port, but for some reason dji decided to put a proprietary square microusb port for its controller to phone cable, but this "square" port does not have the normal micro USB design so the charge adapter can be inserted the wrong way.
I couldn't figure this out when I first got it, because I tried plugging in the adapter the wrong way, looked at it (adapter end is normal microUSB), and visually inspecting it its natural to assume the adapter is not designed for that port.
Either change the adapter to your proprietary microusb connector, or change the controller port to a normal microusb. |
