zauberhd
DJI Susan Posted at 2018-2-1 19:55
I've received your message in PM, thanks! Per the SN, confirm that the drone has not been activated. May I know which port do you connect the RC? The side one or the bottom? Please change to another port if applicable. Make sure only one port is plugged at one time.
Hi Susan,
Thanks for confirming that the drone is not activated.
However, in my original post I clearly stated that I had connected the drone using 3 different devices and using both ports each time and I have ensured only one port is connected.
No matter what device I use (iPad, iPhone, Note s8) or what port I use (side port or USB port) the activation prompt does not appear.
I am using the DJI Go 4 app and I have tried everything. |
