Addie
Flight distance : 48704 ft
Pakistan
Malakai_UK Posted at 2018-2-1 07:28
Yes, you can combine them as the spark shoots at 30fps (29.97fps) and the iphone at 60fps the spark being half the fps as the phone. It would be tricky if you shot at say 24fps and 60fps.
You will need to work on a timeline set to output at 1080p@60fps.
Just remember, if your timeline is at 60fps and you add a spark clip, it will play the spark clip at 60fps or twice as fast. You will need to interpret this clip up to 60fps. You may need to use optical blend for the frame blending method too. What this does for example takes frame 1 and frame 2. looks at whats different and creates a new frame in between 1 and 2 and repeats this between each frame. Doubling the framerate to 60 without introducing stuttering or speeding up the footage.
Thanks for the help, its a little hard to understand at the moment but thats another thing :p
Well im using FCPX |
