AirSnaps
Flight distance : 5423 ft
cyborg Posted at 2018-2-1 06:42
did you try pulling the cable out of the bracket and inserting it properly into the phone ? if not switch off the remote, insert the cable connector firmly (remove from the bracket and push the connector firmly into the phone) and then try connecting again. A friend here had the same problem, it turned out he was trying to connect the phone with a case on it and the connector cable was not inserted properly.
cable is definitely inserted fully, tried with case and with no case, I get the buzz when the cable goes in and the phone starts charging, just the DJI Go app doesn't see it. |
