Osmo mobile stand is wobbly
2048 12 2018-2-2
Yum
The Osmo branded table stand for the Osmo Mobile the $15 one is  wobbly. Is this normal?
2018-2-2
Hi Yum, sorry that I didnt get your post very clearly, do you mean the Osmo Base is not stable? If yes, any chance to show us a short video about the issue? Thank you very much.
2018-2-3
Yum
DJI Mindy Posted at 2018-2-3 00:41
Not the base but the fitting of the handle of the OSMO into the base. I have to jam a business card into the base to keep it stable. If you still need a video I'll do that, however I've seen this same  complaint from others so it seems that it's the actual mold that has been made wrong. It does work if it's put in facing the wrong direction though. If it's turned so that the locking mechanism is on the wrong side of the handle then it sits in there firmly. But then it's not locked in.
2018-5-9
minimoo
yes mine's wobbly too. pretty bad design.
2018-6-7
jeffbake
Flight distance : 955587 ft
If I'm going to use the base for timelpase work, I slide a piece of folded paper in next to handle and base for a more solid connection.
2018-6-7
Terry Lau
I bought one and it is very good
2018-6-7
DJI Tony
Do you mean that the Osmo itself will not fit perfectly to the Osmo base? Kindly check the picture below.
2018-6-7
Yum
DJI Tony Posted at 2018-6-7 15:18
[view_image]
Hi Sorry for the late reply. Yes I have that OSMO base and It is very wobbly if it is put in the correct way around so that the latch clicks in to the handle. If the handle is put the wrong way around so that the latch   does not lock on to the handle then it fits OK.
2018-7-29
DJI Tony
Yum Posted at 2018-7-29 01:19
Hi, would it be possible if we can provide a short video of this issue so that we could check it for you?
2018-7-29
anthonyb
Flight distance : 486381 ft
New Zealand
I have the exact same problem.  The handle in the base is wobbly, not a perfect fit.  Video not needed as plenty of people have the same problem.  The base is not a well made.
2018-8-10
hihenning
Sweden
anthonyb Posted at 2018-8-10 01:43
Same problem here.
It fits better if you mount the handle the wrong way (!).
2018-10-13
ataraxia
I have this same problem, and it's very noticeable. Putting the Osmo in the bracket the wrong way around keeps it stable, but seems rather daft.
2018-10-25
bjashton
Flight distance : 245932 ft
Are you not screwing the base into the tripod mounting socket on the bottom of the handle?
See...
(I confess I bought - https://www.amazon.co.uk/gp/product/B07GST1C2Z which is very stable. It also avoids the issue in the review video as it is mounted flat on the bottom of the handle.)
2018-11-20
