Bad video recording - large green sections
3931 30 2018-2-2
AirSnaps
Flight distance : 5423 ft
I tried recording some video on my Mavic yesterday and a couple of the videos were fine but most had green sections all over them, when played in VLC, in other apps the videos really choppy, jumps around and skips sections. I reformated the SD card and tried again today and got the same results, just tried on the internal 8GB and it's the same on there.
Anything I can do I do I just have a bad Air?
2018-2-2
eYeSkYeYe
Looks like maybe not lemon but certainly limette to me.
2018-2-2
Tomcatuk
Flight distance : 28743 ft
Definitely try another card....
2018-2-2
AirSnaps
Tomcatuk Posted at 2018-2-2 06:08
does the same on the internal storage so I don't think it's the card
2018-2-2
Tadango
Flight distance : 232359 ft
Try a factory reset..... if that does not help it might have to go back.
2018-2-2
Tomcatuk
Did you fix it be nice to know the outcome?
2018-2-8
A CW
Flight distance : 13978875 ft
What device are you using?
2018-2-8
AIister
Flight distance : 626647 ft
what does the video look like if you import it into a video editor?
2018-2-8
AirSnaps
A CW Posted at 2018-2-8 04:44
Not sure if you mean the drone or the PC so
Mavic Air
Custom built PC with
I5 6400
8GB RAM
Nvidia Geforce 610
22" AOC monitor
2018-2-8
AirSnaps
AIister Posted at 2018-2-8 05:11
Not tried that, I'll give it a go later, I've tried refreshing the firmware and calibrating everything but the calibrations failed and I haven't taken it out since.
I'll try to get out with it tomorrow and see if I get any better results.
2018-2-8
A CW
AirSnaps Posted at 2018-2-8 08:24
Mavic Air
Device means what you are using to view the live feed i.e. an iPad, iPhone or android equivalent. These green patches are generally glitches caused by a weak device &/or sd card.
2018-2-8
AirSnaps
A CW Posted at 2018-2-8 08:31
This is on the recorded videos on my PC, the live feed on my iPhone 6 is fine.
2018-2-8
A CW
AirSnaps Posted at 2018-2-8 08:32
I see! I hoped that wouldn't be the case. If this is taken from the internal storage so no micro SD card... you may have a defective drone mate and need to return it!
2018-2-8
Malzuko
Flight distance : 1961969 ft
I am having the same issue
I purchased  A Samsung 128GB 100MB/s (U3) MicroSD EVO Select sd card from amazon to use in my Air and the 4K video 30/25/24fps is all distorted, it gets all pixelated and green blobs appear its really annoying
https://www.amazon.com/gp/produc ... 00?ie=UTF8&th=1
However 2.7K seems to work OK
I was also experiencing this issue with the Internal storage  I hope its not an issue with the unit itself
I just purchased another card on the approved list hopefully it will work better its the SanDisk Extreme PRO microSDXC 64GB  https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
2018-2-8
AIister
did you import the video into an editor ?  you can get green blobs if there is an error on playback on a pc.  driver issues, hardware decoding issues... can tell though if the video is exactly the same, the blobs are identical if you skip ahead or back etc.  if you post a short mp4 on dropbox or something i can analyze the file and see if anything shows up.
2018-2-8
mainstain
Flight distance : 178566 ft
Malzuko Posted at 2018-2-8 09:38
I have the exact same SD cards, and got one blip of green while using the Samsung card. Did some testing and this is what I found.
SanDisk Extreme PRO U3 V30 microSDXC 64GB
Look at those write speeds. I think we will have more luck with the Sandisk.
Interestingly, I also tested a Samsung 256GB 100MB/s (U3) MicroSD EVO Select
2018-2-8
Malzuko
AIister Posted at 2018-2-8 09:49
Thanks for the suggestion, I watched the video a few times and the distortions are not consistant,  I am just plugging the SD card into the computer, transferrng the file then playing it with VLC, Im new the video portion of RC aircraft  so im know I gotta be doing Something wrong I uploaded the video to youtube to see if that helped and there was no distortion, Here is a sample video via wetransfer
https://we.tl/6YVEsvblmj
2018-2-8
AIister
test size is different, samsung says 1GB and the other two say 500MB - i would like to see all at 1GB
2018-2-8
AIister
Malzuko Posted at 2018-2-8 10:09
cool.  getting somewhere.  video plays fine for me.  video specs are all good,  corruption or dropped frames and bitrates and codecs are all good.  it's a playback issue.. what software are you using to play it back?
2018-2-8
Malzuko
AIister Posted at 2018-2-8 10:17
[view_image]
I am using VLC 2.2.4
2018-2-8
Malzuko
I am feeling it is an issue with my computer here at work, I am satisfied that it works for you!
2018-2-8
AIister
go into preferences and video and at the bottom press reset preferences.  im on 2.2.6
could be video card or drivers or something else that can't handle the full 100+ mbits of data.
i remember way back in the early days of divx, computers weren't optimized and no hardware decoding so right at the best part of the porn everyone would go green and blocky .. life is good now.
2018-2-8
Malzuko
AIister Posted at 2018-2-8 10:36
thanks for your help!
2018-2-8
hallmark007
Flight distance : 9827923 ft
https://forum.dji.com/thread-117830-1-1.html
Here’s a link with similar problem might help.
2018-2-8
mainstain
AIister Posted at 2018-2-8 10:12
You're right. Good call. I tested them all at 500 MB, but re-ran just the Samsung 128 GB card again at 1 GB to see if it was a fluke. There was next to no difference with the Samsung 128 GB card between 1 GB test size and 500 MB test size, but I happened to not save the 500 MB test size screenshot.
Here they are with 1 GB test data. No real difference.
One more for good measure, this is a SanDisk Extreme U3 V30 microSDXC 128GB
2018-2-8
Tadango
On my PC i could not play back all 1080p 60fps files and all 4k 30fps files. They looked corrupted. SD card or internal storage did not matter. Then i took my laptop..... all files played perfectly. Time for a new PC
Btw, i use a cheap Samsung EVO 64GB card and it works great. Write rate is 63MB/sec under Windows. More then enough.
2018-2-8
Hexacopter
G'day. be careful where you purchase your SD cards as there are plenty of fakes out there Fake SD Cards. This is one device that I always purchase directly from a reputable supplier.
* hex *
2018-2-8
dronybaloney
Flight distance : 24897940 ft
Yep looks like the same problem i have with my ipad mini 4. This has a a8 chip, just not a8x.
It seems that everytime dji does fw updates and dji go 4 updates, that you need a faster chip.
Probably they have some kind of secret agreement that people have to buy devices with faster chips.
I bought the ipad pro 10.50inch, which has an a10x chip.
So i will be ok for maybe a year ,then i have to buy a faster one again and again and again
2018-2-8
AIister
Tadango Posted at 2018-2-8 13:01
typically don't need a new pc.  modern $50 video cards have all the hardware decoding needed for this type of stuff.
2018-2-8
RPG2
I also got this problem, Fixed it.
I noticed that I had very old VLC player, I hoped that upgrading the player will help and it did.
Small thing to try before you buy a new hardware.
2018-9-25
djiuser_Sx2UM918vu2y
Hey, I'm working on an art project and wonder if you still have this footage? I really like this glitchy kind of stuff. If so could I please use it?
Thank you
2020-5-24
