luciens
I'm cautiously optimistic, though, that at least some of the bugs will get fixed now that they appear to have been reported to DJI. I've done software support myself for many years and I know how tough it is to get actual reproducible cases for actual true bugs, and filter those out of user error, etc. Especially on a new product that only a few folks are using out in the field. So I'm hopeful these problems are sufficiently reproducible (and therefore fixable) at DJI.
That said, the video part of it seems to have only one really major bug - the range issue when frequency selection is set to auto - and that can be easily worked around by manually selecting a channel. I've been testing that and sure enough the range seems to approach what's advertised for the unit with a hard-coded 2.4ghz channel. It's even almost as good at a 5.8ghz channel, so the hardware is probably ok.
The /roll of death/ is a tossup; in my case and in the other reported cases, it's still not known if it was the air unit or something else at fault. It could have been as simple as bad connections in my trainer cord for my Futaba transmitter. I was just too shocked to troubleshoot that that day and I didn't go into the menu and see if the controls were still working at the goggle end . I'm sort of using my remaining F550 as a guinea pig on that, since I have it also setup with ocusync R/C like the one I lost. This time making sure my connections are secure and things are setup right in my Wookong controller, etc. I've taken all the stuff out of it that I wouldn't want to lose if it augers in, so.....
So it's a 50/50 thing at this point for me. The quality of the video is definitely good enough to not abandon it, at least in my case, and i'll just hope some of the bugs get fixed... |
