Mavic Air Slow unless in Sport mode
4571 11 2018-2-2
fans2d98322e
Flight distance : 30843 ft
When flying in regular mode the drone moves extremely slow, any ideas on how to improve performance or setting recommendations. When in Sports mode there is no issues.
2018-2-2
A CW
Flight distance : 14177772 ft
Turning off OA will increase the air speed to the maximum cruising speed in p-mode - though be careful if flying at lower altitudes as the drone will obviously be blind to obstacles in all directions.
2018-2-2
MiniPalourde
Are you flying in high winds? Have you disabled ''beginner mode''?
How fast is ''extremely slow''?
2018-2-2
Bekaru Tree
Flight distance : 15513100 ft
South Africa
when you say it moves extremely slowly are you refering to aircarfts actual speed or are you refering to speep of gimbal movement, and yaw speed ect. If you means aircraft speed - then the way to do it is via sport mode - with practice and control you can make a drone move fast or slow in sport mode. if you are takling about gimbal and yaw speed etc - then these you can adjust by going into your settings - there are a few places that these various speeds can be adjusted -
2018-2-2
Tom.CH
Flight distance : 47156 ft
Switzerland
Got about the same "feeling" today, on first flight with my new Mavic Air, compared to the Mavic Pro it seems to be rather slow in movement... but hey this drone is made for very small environments where flying a Mavic Pro cloud be easily dangerous... So saying the Mavic Air is slow, in my opinion is false, since it isn't unless in direct comparison with another much bigger drone...
2018-2-2
fans2d98322e
Yes I am referring to actual speed. I would still like to maintain OA. I will fly the craft again and make not of the actual speed. I have disabled biginner mode.
2018-2-2
MiniPalourde
Tom.CH Posted at 2018-2-2 12:52
OP said extremely slow. I think he has some settings wrong or even a faulty unit.
2018-2-2
fans973b419a
Flight distance : 1406834 ft
I have the same problem as OP, but the Mavic Air is slow in comparison to my Spark. I don't have beginner mode enabled. The drone feels like it is in tripod mode.
2018-2-13
fansfb7ef039
Flight distance : 147569 ft
same here, it feels extremely slow compared to my Spark... I wonder if something is wrong with the unit
2018-2-14
fansdeb85d2b
Flight distance : 140978 ft
I feel like its descent and take off speeds are really slow in comparison. Im only getting 2.8mph descent speed.
2018-2-14
fansfb7ef039
fansdeb85d2b Posted at 2018-2-14 09:59
yeah, I get about the same, 2.9mph descent speed in GPS mode
2018-2-14
Sim-Y
Flight distance : 75502 ft
If o/a detects anything the drone will go very slow no matter how far you push those sticks.
2018-2-14
