djiuser_QPNYJWRGgFNs
Flight distance : 96188 ft
DJI Thor Posted at 2018-2-3 01:26
Hi, in normal mode, the front LEDs will be solid red to indicate the head of the drone. It might be in the intelligent flight mode if it turns to be solid green. For example, Follow in Smartcapture. You can read the manual for more info.[view_image][view_image]
I encountered the same situation a few times as fanscd29b0cb described. The leds were in green and turned to red after battery changed.
I am sure I didn't put the air in any intelligent mode. Anyway, it flied normally. |
