Please help! Defective Mavir Air? Noisy shadows
3990 26 2018-2-2
Spark23
Flight distance : 70577 ft
Hi all -
I’d really appreciate input from the forum here. So far my Mavic Air has flown perfectly, but I’m seeing really weird noise and brightness shifts in shadow areas. I’m shooting at 4K 24fps on the Normal color profile.
Would you mind watching the video below in 4K and see if this is expected/normal?  Quality doesn’t look acceptable from my perspective.
https://youtu.be/tQQ4NWumOc4
Thank you
2018-2-2
S.D. Pilot
Flight distance : 10278435 ft
Looks fine to me. Don't panic it's probably because it was facing directly at the sun and camera was adjusting. Try different angles, away from direct sunlight.
2018-2-2
Spark23
Yeah, I'm not so sure.  Yes it's facing into the sun, but it shouldn't be that damn noisy.  Here is another video at 4k... watch the shadows in the grass on take off.  They actually shift brightness quite a bit, even though I was on manual exposure.  Not sure what to think at this point...
2018-2-2
lannes
Flight distance : 4465 ft
I see the pixelation at 38 seconds in the cul de sac, I think this is due to the dynamic range of the view being to wide with the rising sun and shadow areas.
2018-2-2
DJI Susan
Hi there, does the issue appear if changed the aircraft direction? If yes, please upload some original videos in the SD card and upload to Dropbox, we'd like to check the exact status.
2018-2-2
Chasing Light & Shadows
Flight distance : 221476 ft
That's actually really good considering the size of the sensor and the position of the sun.
2018-2-3
Montfrooij
Flight distance : 2560453 ft
Indeed a lot of noise on 4k.
But maybe it is not noise, it can also be compression (artifacts).
Try the highest bitrate.
2018-2-3
Spark23
Montfrooij Posted at 2018-2-3 06:59
Is there a way to manually set the bitrate??    Right now it's horribly noisy even in good daylight
2018-2-3
Spark23
DJI Susan Posted at 2018-2-2 23:58
Hi Susan -
I've uploaded a video from today on dropbox - link below.  Look at the water in the scene - it's just horribly noisy even though this is taken in very good daylight.   Any thoughts?  Is my unit defective?
https://www.dropbox.com/s/lfwwyv90me4csfn/DJI_0017.MP4?dl=0
2018-2-3
A CW
Flight distance : 13877205 ft
Use ND filters when flying directly into the sun.
2018-2-3
Spark23
A CW Posted at 2018-2-3 09:43
Yes, I know. But even not flying into the sun the noise is pretty awful.
2018-2-3
A CW
Spark23 Posted at 2018-2-3 10:44
Yes, I could see in the vid over the lake - thats not too good! Play around with the settings but you may need to get a replacement
2018-2-3
fans6130bec4
Are you using a slow SD card?  It's possible (my speculation only) that the drone recognizes a slow card and over-compresses 4k video to be able to write continuously to the card.  Maybe a faster SD card would help?
2018-2-3
Spark23
fans6130bec4 Posted at 2018-2-3 11:23
I’m using a fast micro SD card - class 10 / UHS3 from Samsung. Don’t believe that is my problem, as the internal memory was showing similar issues. I’m giving it another week and then I’ll return, if DJI doesn’t have any solution.
2018-2-3
PedalingDuo
Flight distance : 31896 ft
Spark23 Posted at 2018-2-3 09:36
Hi Susan -
I don't know if it is my computer or what, but when I watch the Dropbox Lake Video I see a slow strobe of noise in the video.  It seems that every second it is alternateing from clear to grainy.
Again, don't know if it just me.  Do you see that effect?
2018-2-3
eYeSkYeYe
Croatia
Spark23 Posted at 2018-2-3 13:07
What was the ISO setting for the shot?
2018-2-3
Jeff7577
Flight distance : 1916821 ft
Sounds like you should return the Air and get a Phantom.
2018-2-3
Montfrooij
Spark23 Posted at 2018-2-3 09:35
I'm not sure. If you can, it is in the video settings menu.
2018-2-4
0Kajuna0
Flight distance : 267126 ft
I've seen that problem in other Mavic Air videos: https://forum.dji.com/thread-132762-1-1.html
Maybe a software issue that could get fixed eventually? (Mavic Pro still waiting for a sharpness/noise_reduction fix)
Edit: Try setting Sharpness to the minimum value, or 0 or 1 (not sure if it will work like in the Pro) and see what happens
2018-2-4
No Man's Drone
Flight distance : 301545 ft
I was getting this issue when I was using the same SD card you are using. I am using a Samsung Pro+ 128GB microSDXC UHS-1 and I'm happy to say that it is perfect.
It is your SD card that couldn't keep up with the video write speed.
2018-2-4
Berg I Imagery
No Man's Drone Posted at 2018-2-4 09:36
Interesting....  I’ll try another micro SD card just in case. Thanks again
2018-2-4
DJI Susan
Hi Susan -
Received with thanks! I'll forward to our engineers for review, will come back as long as there is an update.
2018-2-7
Berg I Imagery
DJI Susan Posted at 2018-2-7 05:05
Thanks Susan!  Any word from the DJI engineers?   I've dialed back my settings to reduce the noise, but I still see it especially in evening shots, even at ISO100
2018-2-10
DJI Susan
Berg I Imagery Posted at 2018-2-10 07:19
Sorry for the late response. I just got the message from our engineers that they need more data:
1. What's the current firmware of the aircraft, controller, and APP? You can check this in General Settings>About
2. What's the ISO in the sunset video? Could you upload some samples in ISO 100, Shutter 1/30 and J+R for further analysis?
Thanks in advance!
2018-2-23
djiuser_WyjxnSrYyvcd
Greece
Did you managed to fix the problem? I have the same problem. Very noisy shadows.
2018-3-14
djiuser_J0azN4jjmwif
I too am having this problem. Very Very noisy shadows and moderately noisy mid-tones.
2018-8-7
raphael_bellizzi
Flight distance : 757976 ft
I'm having the same problem and it makes me sick! I came from the Mavic Pro and Spark and I've never got this problem before. ISO 100, Shutter 1/30 or 1/50 or 1/60 and even automatic mode I get this noise in dark areas!
Fortunately i have the Neat Video Denoise because I work with videos, but it was expensive and I don't wanna do this slow process in all my videos.
2018-9-13
