fans1e2e5a9d
Flight distance : 141033 ft
Hi JoeColorado. Firstly, OccuSync and Lightbridge HD have separate channels (control channel and data channel for video) which are time division multiplexed. This results in much faster and more stable transfer rates of data, hence the stuttering. Wifi isn't really hugely different: it still uses radio waves in the 2.4GHz and 5.8GHz bands, but does have more limited range. I expect the more expensive Phantom and Mavic Pro also have better, more shielded transmitter / receivers than the Mavic Air (I own one as well as a P4P). Best thing is to down rate data bandwidth in the Go App settings in areas of significant interference, and stay at close quarters to the drone, and use 5.8ghz where you can (the higher frequency = wider channels, = faster transfer rates than 2.4GHz which has less than half the bandwidth capability and is a VERY well used, nearly saturated actually, frequency band used for a lot of modern devices and applications) |
